d model motorgrader
ghost1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ghost1 Quote  Post ReplyReply Direct Link To This Post Topic: d model motorgrader
    Posted: 31 Dec 2017 at 5:50pm
I just picked up a d model grader and looking for any info ser.# D-3493   eng. # 45-5465-G eng. is locked up won't turn over does anyone what engines might fit or if this could be rebuildable
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2017 at 5:59pm
WC, WD, WD45, D-17 should all bolt up...
From your serial # it appears to be 1953
Post Options Post Options   Thanks (0) Thanks(0)   Quote ghost1 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2018 at 8:28pm
thanks now to do the search for an eng.
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2018 at 11:25am
Ghost1 ..  You better  over haul   what you  have  that  is  a special  crank  to use   the  big  pulley.  Tony
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2018 at 1:48pm
I overhauled our D, Serial number D-4997. The crankshaft is unique to the grader engine. (WD-45 engine).  Mine was cracked severely, but was lucky enough to find a replacement.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
