D Grader Diesel Engine and Injector Pump
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Topic: D Grader Diesel Engine and Injector Pump
    Posted: 16 Aug 2020 at 5:34pm
A neighbour has one and he's looking for a replacement pump.
Just curious as to what they used
TIA
Ian
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2020 at 6:57pm
I thought all "DD" graders used the Buda 230 diesel engine similar to the WD45 tractor. If so, it should be an American Bosch rotary injection pump. Now, if someone has transplanted a Buda 262 engine from a D-17 in it, they used a RoosaMaster injection pump.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2020 at 6:25am
D and DD graders had the same engines as current tractors. When the D-17's arrived, they had the G-226 and the 262 diesel. Check the grader serial number for the year.
Steve allis dozer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 8:25pm
Hi Ian  some of the early diesel graders here had CAV pumps i will check mine and hopefully get some numbers for you
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 4:24am
Thanks everyone.
Seems this is a 260 with a Roosa and the pump must be sick.  I don't know why not rebuildable.
Steve - if a CAV might swap it would probably widen his possibilities down here
This page was generated in 0.242 seconds.
