D Grader Diesel Engine and Injector Pump |
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1002 |
Topic: D Grader Diesel Engine and Injector PumpPosted: 16 Aug 2020 at 5:34pm |
A neighbour has one and he's looking for a replacement pump. Just curious as to what they used TIA Ian
Posted: 16 Aug 2020 at 6:57pm |
I thought all "DD" graders used the Buda 230 diesel engine similar to the WD45 tractor. If so, it should be an American Bosch rotary injection pump. Now, if someone has transplanted a Buda 262 engine from a D-17 in it, they used a RoosaMaster injection pump.
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4561 |
Posted: 18 Aug 2020 at 6:25am |
D and DD graders had the same engines as current tractors. When the D-17's arrived, they had the G-226 and the 262 diesel. Check the grader serial number for the year.
Steve allis dozer
Silver Level Access
Joined: 10 Apr 2011 Location: Australia Points: 232 |
Posted: 20 Aug 2020 at 8:25pm |
Hi Ian some of the early diesel graders here had CAV pumps i will check mine and hopefully get some numbers for you
Ian Beale
Posted: 21 Aug 2020 at 4:24am |
Thanks everyone. Seems this is a 260 with a Roosa and the pump must be sick. I don't know why not rebuildable. Steve - if a CAV might swap it would probably widen his possibilities down here
