D Gas Grader Serial Location
GreenOrange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Topic: D Gas Grader Serial Location
    Posted: 01 May 2012 at 5:00pm
Where is the serial number located on a Model D grader (not the engine, the chassis)?  Thanks!
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2012 at 10:01pm
The serial number should be on a brass tag rivited to the channel frame just below where you mount the grader on the right side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2012 at 9:12am
I checked it out, and the tag is definitely missing... when I looked close in that area I could see where a couple rivets were.  Was it stamped anywhere else?  It's not a huge deal, I'm just trying to figure out what year it is.  By the engine number, I'm guessing about 1951 or so.
Thanks
Ken stanwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken stanwood Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 10:53pm
Hi, I was wondering if anyone can help me identify my Allis. I know slightly less than zero about tractors. It is supposed to be a 1964, its yellow and has a front loader. There is an aluminum tag on the right side of the loader and the tag number is L-200   2U670-AC. Any help would be appreciated. I can get a pic if that would help anyone. Thanks for your time, Ken.
