cylinder seals
rubeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rubeman Quote  Post ReplyReply Direct Link To This Post Topic: cylinder seals
    Posted: 06 Oct 2010 at 7:46pm
i've got a set of cylinders on a freeman loader that have 1 3/4" rams with a 2 3/8" bore. The seals look just like the ac part# 72000650 (1-1/2" id x 2" od) only bigger. Any idea where I can get them It takes 4 per cylinder. It appears the cylinders are built by the same company, as they are  identical except for the ram and bore size. thanks in advance.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 7:56pm
Try the local hydraulic supply store.  They should be able to point you in the direction of someone who carries cylinder seals if they don't.  That's how I found a guy that has a warehouse of seals about 30 minutes from me.  A lot cheaper than AGCO prices too if they can get the seals you need, that is you don't have something that is non-standard.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 8:24pm
Try Baum Hydraulics, www.baumhydraulics.com
Gerald J.
