cylinder seals |
rubeman ![]() Bronze Level ![]() Joined: 07 Aug 2010 Points: 6 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Oct 2010 at 7:46pm |
i've got a set of cylinders on a freeman loader that have 1 3/4" rams with a 2 3/8" bore. The seals look just like the ac part# 72000650 (1-1/2" id x 2" od) only bigger. Any idea where I can get them It takes 4 per cylinder. It appears the cylinders are built by the same company, as they are identical except for the ram and bore size. thanks in advance.
Hurst ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Midway, Ky Points: 1213 |
Try the local hydraulic supply store. They should be able to point you in the direction of someone who carries cylinder seals if they don't. That's how I found a guy that has a warehouse of seals about 30 minutes from me. A lot cheaper than AGCO prices too if they can get the seals you need, that is you don't have something that is non-standard.
Hurst
1979 Allis Chalmers 7000
5800 Hours |
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Try Baum Hydraulics, www.baumhydraulics.com
Gerald J. |
