Cylinder head/manifold erosion
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 4:21pm
Yeah, well, my D17 had erosion on the manifold, which I corrected by face-milling the manifold and installing new gaskets... in this case, though, the manifold runners were perfectly fine, but the erosion was on the head instead.  I'm sure that had someone found it shortly after the gasket blew, they would've fixed it, but they didn't...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 10:21pm
HERE's what it looks like now:
Edited by DaveKamp - 23 May 2010 at 10:22pm
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 5:51am
Dave - sure looks like you cured the problem! I am inches away from installing a new-to-me manifold on my WD45 - manifold checked out nice and flat - we will see about the head - several of the manifold gaskets were completely history when the old one came off, but I didn't see any obvious erosion like you had. We'll know for sure when we test-fit the manifold.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 10:32pm
Okay, the verdict is in:
Milling the head worked perfectly.  Nice, tight seal, no problems.  Lapping the valves was a good idea, too.  She runs well.
Initially, it was leakin' around the head in a couple of places. I let it get good and warm, then shut her down... I went back and retorqued the heads.  Obviously I had a little coolant dribbling in, 'cause it sent up a cloud of steam when I lit it back up, but after that, no leaks or bubbles, and a shutdown, wait a few, restart resulted in no smoke.
