Cutting thick steel plate
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Cutting thick steel plate
    Posted: 14 Nov 2018 at 4:48pm
I just bought a 2’x3’ piece of 1 1/4” thick steel plate. I need to cut it in to 6” strips. I don’t think my torch is big enough. Any ideas?
Joe would be so proud of what I paid for this.
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2018 at 4:59pm
They have a computer operated plasma cutter at the steel shop I use, they don't charge much to set up and do all cuts.  You might call the bigger steel places and see if they can accommodate, faster and will be done right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2018 at 5:19pm
I like that idea. I’m gonna call the local welding shop and we have a big machine fan shop.
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2018 at 6:47pm
 Whew,,,,,lets see 2 ft by 3 ft and only 6" strips ,,,,,,,,HMMmmmm,,,tryin to calculate how many cuttin discs it'd take  to do the whole thing,,,,UMmmm,,maybe takin it to a shop be best,,,,,,WinkWink
 What you makin that thick,,??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2018 at 6:59pm
I told you wrong. It’s 2’x4’. I need to make 2 cross cuts and then (3) 3’ cuts. I’ll weld them all together to make a 5”x6” square 3’ long. It will stand on end and be the anvil for my power hammer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2018 at 8:23pm
HOLY CHIT!!!  IF,,,,,,,,,I can member correctly,,,,,,,,,,1-1/4" thick by 1" square is 4-1/4 LBS per FOOT....so,,,,,,,,,you got EIGHT sq feet of that,,,,,,,is ,,,,HOLY CHIT,,,,,,,,,I ain't got that many finger and toes!!!
HOW you movin that around??
Anvil for a POWER HAMMER???  Good thing I don't live next to you,,,,,,I like my sleep uninterrupted...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2018 at 8:26pm
Oh Yeah,,,,,,,,I member from class that a 1 cubic inch of steel weighs as much as a chebby engine.  NO,,,,,,,,,wait......not AS MUCH,,,,,,it's .283 POUNDS.... .283,,,thas a chebby engine.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2018 at 8:58pm
Done a little math on that steel.Got .83 of cu ft at 475 cu ft equal 394 lbs .Might  not be absolute correct but worked around steel for years and know it is heavy.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2018 at 10:18pm
Band saw or power hack saw of some sort. I had some 1 1/2 x 5 I wanted to make some weights and just used a cheap power hack saw. It didn't cut that hard.
Edited by DanWi - 14 Nov 2018 at 10:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2018 at 5:57am
Aw come on guys.. use a cold chisel and a hammer !Wink After all he's 'blacksmithing', so 'old school is the rule' Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2018 at 6:38am
Can use hand held torch.No 2 tip,10 to 12 lbs actly and 65 to 75  oxy. Use peice of angle for stright edge and slowly drag it by .P S If you use a hacksaw it will need a big bow for clearence !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2018 at 7:24am
Whoa whoa whoa. I thought we decided you was a moving here for some Red state politics and and and a guarantee Bert I mean Brett wouldn’t ever be yer coach.about that blacksmithing, you come over one time and hang with us on Blacksmith night and you’ll be hooked.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2018 at 8:23am
There is something about beating steel into submission that is so satisfying. Man that's heavy.
Edited by chaskaduo - 15 Nov 2018 at 8:23am
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2018 at 3:24pm
ya, I get 407 pounds
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2018 at 6:37pm
Thad,
I think we need pictures!
Ok that is thick material to do by hand. Could be done but you might not like the look of the edge. The recommendations on tip and torch settings may be right on. We had a torch cutting bug that followed a line or a pattern. Getting the torch set right and it will do the job on that thick stuff too!
Edited by Sugarmaker - 15 Nov 2018 at 6:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2018 at 6:37pm
    Well,,,Ya see,,,time you deduct all them shavings from all them cuts,,,it'd be close to 405.35698 lbs,,,,,Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2018 at 8:02am
Joe  Clap
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2018 at 1:21pm
Not sure what you have for a torch, but about any name brand torch out there is capable of cutting up to six inch plate with the proper tip, and the heavy ones will easily go double that, getting a tip for 1 1/4" plate should be a cinch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2018 at 1:30pm
Thad,
And remember its only steel. it can be welded or cut more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2018 at 6:15pm
I have a small Victor and a larger Harris. I need a new regulator. I assume oxygen but not sure? It drifts and has to have constant adhustments
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2018 at 8:49pm
Ned two stage regurlator when cutting comesuming large amount of  oxyg.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2018 at 2:16am
whew!
This page was generated in 0.107 seconds.
