CUT OUT SWITCH WIRING FOR WD |
C & J Plumbing ![]() Bronze Level ![]() ![]() Joined: 14 Jun 2011 Location: OHIO Points: 6 |
![]() ![]() ![]() ![]() ![]() Posted: 14 Jul 2011 at 9:43pm |
I have a wd that is wired from amp meter to battery side of cut out switch. when you shut the tractor off you still have power to the opposite side of cut out if you disconnect battery terminal it cuts out. Wondering if the battery side of cut out should go to the switch. Any help would be greatly appreciated. |
Chalmersbob ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
sounds like the cutout is stuck closed allowing current to past through the contacts.
Remove the cap and check the contacts. If they are stuck, gently pry them apart and check them for pitting.
Bob
