Cut out relay to voltage regulator |
Post Reply |
dr p
Orange Level Joined: 24 Feb 2019 Location: new york Points: 1011 |
Posted: 09 Aug 2020 at 6:45am |
My 6 volt generator was on the fritz so I took it to my local automotive electrical shop for maintainence and she replaced the cut out relay with a three position voltage regulator. I assume the green wire still goes from the resistor to the generator field terminal. But where does the wire from the discharge side of the ammeter go? And since I have a three position light switch, do I now need a two position one?
ac45dave
Orange Level Access Joined: 23 May 2015 Location: SE(IN) Points: 1319 |
field wire to switch box no longer needed with regulator.field on gen to field on reg.arm on gen to gen/arm on reg. Hot bat wire to bat on reg.
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11549 |
Actually, moving to a VR is a nice upgrade for the 6V system. You won't need the 3 position switch for the charging side of the system anymore, but if its equipped with headlights, the switch will still take care of that side of the equation.
Wiring to the VR would be: "F" (Field) to "F" post on Gennie, GEN or "G" to "A" post, Ammeter Neg. side (-) to BAT or "B" terminal on VR. To Polorize, jumper wire from "B" or BAT to "A" or GEN terminal on VR for a couple seconds. You'll get a spark, that's normal. Then fire the Tractor up... Steve@B&B
dr p
Thanks guys
Post Reply | |
