Cummins powered Allis 180
rowcropmafia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowcropmafia Quote  Post ReplyReply Direct Link To This Post Topic: Cummins powered Allis 180
    Posted: 24 Aug 2016 at 9:59pm
One-eighty for sale. 5.9 cummins powered. Roll cage. 18.4-38 double cut radial firestones. Runs 8th gear.Indoor smoke tube. Triple disk clutch. Lots of good parts. Weighs around 5000lb bare. Competitive in IPA outlaw class. Located in central Illinois. 217-255-3678 Ben
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2016 at 6:58pm
Is this the one on Pulloff for $25,000 ?
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2016 at 7:17pm
Yup.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2016 at 7:20pm
Its on YouTube , right?
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2016 at 10:21pm
Hope these are the right ones...
Allis Chalmers Indecent Exposure 2016
 [TUBE]e1xetLvUAf8[/TUBE]
[TUBE]eHvqC3AvK3A[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2016 at 4:03am
Nice machine, she runs great!
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowcropmafia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2016 at 9:23pm
Yes, it is advertised on pulloff. It is a good running tractor. Very popular class in my area. If it sells i would like to build a light limited super. If it doesn't it won't hurt my feelings. I'm having a lot of fun with this one
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2016 at 10:55pm
Maybe it's just two tough tracks, but I'm used to spinning things out instead of run-and-snuff. Need a gear between 7th and 8th ?? or lower the drawbar an inch ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowcropmafia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2016 at 11:48pm
It could use a gear just a little slower than 8th. I have tried things like lowering the drawbar and tossing weight on the ground. Seems like you just lose your speed sooner and it doesn't get it any farther down the track. 7th in that tractor is 27/1 and it will light the tires like a buzz saw but it will be 10-20 foot short of the same pass in in 8th gear. The way the motor is set up currently it doesn't lug the best but seems to make up for it in the top end and holds the speed down the track better than most tractors in the class. I'll have to look in the results but if i remember right those videos are both 3rd place finishes in a class of 12-15 tractors
TeamAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TeamAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2016 at 7:40pm
What does the tractor weigh in the videos, and what weight classes do you pull in?
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowcropmafia Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2016 at 9:48am
6500lb. I always pull that weight, that's all we have around here. We had 27 hooks with IPA this summer so i haven't been going anywhere else
Post Options Post Options   Thanks (0) Thanks(0)   Quote TeamAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2016 at 8:25pm
We pull a 180 @ 6,700 lb. and we are running road gear and spin out on a good clay track. We have only 1 pull per month and there are 3 tractors. Ford 7000 4 cylinder and a 1655 Oliver. We put about 25 + feet on the Oliver. The tractor has really been a good runner, we are out to 360 cui, Allis 301 block.
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2016 at 8:27pm
What size tires do you run? Do you have an A pump or a P pump?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TeamAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2016 at 8:54pm
Running a A pump but will probably go to a P pump this winter. We currently have a set of 24.5 X 32 Firestone single cuts and hope the club will vote in double cuts.
This page was generated in 0.085 seconds.
