Cummins Engine Co
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Cummins Engine Co
    Posted: 12 Nov 2025 at 6:26am
Was accessing some parts at a Local KW dealer, saw a Sign in the parts department but did NOT have my Phone.  Cummins Announced as of Late 2026 into 2027 they will NO LONGER OFFER any form of Manual Transmission Coupling designs.  The Engines will be configured to accept ONLY Two Pedal Automatic Transmission Systems, NOTHING Using a Clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2025 at 7:54am
Its the way of the future... TO many morons cant shift a truck... and AUTO DRIVE by computer needs AUTOMATIC shift.. NOBODY in the seat to PUSH the PEDALS...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2025 at 8:03am
Self Defeating system, produces more that cannot compete nor adapt.  Will not be driving anything to that level any further as will stick to my old junk for the next decade(s) as likely are my last.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 49 minutes ago at 8:54pm
The new auto shifts still use a clutch. Just no pedal. The Allison fluid drive automatics do not. So your 3 choices right now are standard trans, auto shift trans (standard trans but no clutch pedal) or fluid drive automatic same as car. In our International trucks that is the Allison trans (5,6 or 7 speed). They work well but harder on fuel. We still sell a lot of 18 speed standard shifts but mostly for gravel guys. The 18 speed auto shift is also popular. The Allison option is the most expensive. Smile
Edited by Ed (Ont) - 3 hours 47 minutes ago at 8:56pm
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 55 minutes ago at 9:48pm
2 friends that farm have automatics or autoshift trucks. I don't know specifically. But ones a freightliner he has been having problems with electrical stuff related to the transmission. He went thru the power and ground wires before harvest, haven't seen him since to see if he got his problem solved. The other one was a Volvo when harvest started his acted up, after the first couple days of pulling battery cables when it acted up so it would reset, he got it into a shop and the guy cleaned some connections and it has been good thru harvest now. That one wouldn't upshift or down shift when it acted up. I think the one day he drove home from the elevator in second gear.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 28 minutes ago at 11:15pm
Computers don’t truly know when to shift, even some people….
I personally love stick shifts.
Sad to see them go, but I probably won’t own something that new!!
