Cub Cadet 782?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Cub Cadet 782?
    Posted: 26 May 2020 at 8:44am
I bought a Cub Cadet 782 last year. It will not fire. Turns over well. Put new coil on it, no change. I haven't got a manual for it yet. I know some of these had a troublesome switch or two. Any of you guys out there have one of these? What is most likely killing the fire? Thanks Tracy
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 8:51am
Tracy, I have a 782 that is my favorite mower tractor! It's just comfortable for me. On the no fire, would guess the usual suspects? Points, condenser? The deck engagement switch could be a problem, have fought that a time or two. Also have a 1450 and a 1650 CC. Got a new switch off E-bay once that was backwards! 1650 would start if the pto was engaged but not if it wasn't!
Grayray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grayray Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 8:58am
Maybe the seat safety switch, the one where if you lift your butt off the seat, it kills the engine?  Maybe look for a bare wire going to one of the safety switches, maybe a mouse had lunch on the wire during the winter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 9:02am
Grayray, I don't think they have a seat safety switch. One other possibility could be the 'neutral start switch'. My 1450 if you don't have the brake pedal in just the right spot it won't start!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 9:43am
It has a seat switch and the neutral pedal switch. Checked both of them. Has a pto switch lockout also. I wonder if the ignition switch has went bad. Heard that they were a problem. Any help appreciated. Thanks Tracy
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 10:58am
We had to replace the the ignition switch on a friends.  He we just hot wiring it for a while before he decided to change it.  Same problem you have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 11:13am
John, I will give it a look. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 5:42pm
this might help with the trouble shooting.....
'borrowed' from ... https://www.onlycubcadets.net/forum/showthread.php?t=21https://www.onlycubcadets.net/forum/showthread.php?t=21
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2020 at 8:51am
Jay, Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2020 at 11:33am
Always happy to help. If yours has a higher serial number, that website has another wiring diagram....
Jay
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2020 at 11:38am
Don't Know which one you got Serial# wise, but here's a site to download 4 different Operators Manuals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2020 at 11:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2020 at 1:20pm
You guys are info specialist! Thanks tracy
