creeping with a pwershift- will i hurt it?
clint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Topic: creeping with a pwershift- will i hurt it?
    Posted: 20 May 2010 at 10:29am
i bought a 4 row tobacco setter and due to the weight of the mounted tanks (300 gallon) and me not wanting to creat a new frame for another tractor just for a tryout- i might use the 8010 for a few hours- i need to go very slow-
maybe around 1 mph
can i creep along in 1st gear low about 1000 rpm and not hurt the tranny?
Our farms stuff: agco gt55, AA 8775, 8765, 6080, 185, 180, 175, 170, d15, d14, d14, wd, wd, wd, g, F3, L3, R62
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 10:47am
why would it hurt the tranny? its pressure lubed so if your running wide open or at an idle its being oiled, unlike a John Deere, so no damage is going to occour if your just crawling along, Id be more worried about the engine being carboned up from lack of labor , I only say that because an Allis Chalmers was made to work!!!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 11:28am
you have to get 1400 or better to have the pressure warning light for the tranny to go off
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2010 at 3:44pm
bump
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2010 at 4:41pm
1400 for the light to go out, but under that the prssure is still there just not as strong, still wont hurt it
