CRAZY Construction |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35666 |
Topic: CRAZY ConstructionPosted: 07 Jan 2022 at 4:45am |
Was involved in two house tear downs for the local church last two days, refilling the holes with crushed rock to become parking lot. The Second house was a Crazy Weird Construct, only wood was Floor joist and roof structure, Foundation and house structure walls were Clay Tile Block plastered to Inside, concrete to exterior then painted. Supposedly had Leaks EVERYWHERE.
plummerscarin
Posted: 07 Jan 2022 at 7:35am |
Have silos here built that way but block stood on edge. Never seen a house built with that kind of block, and laid flat to boot. Now I’ve seen everything?
JW in MO
Joined: 16 Feb 2010 Location: South KC Area Points: 2696 |
Posted: 07 Jan 2022 at 7:54am |
Well, if I owned a brick factory and had to build a house for my mother in law. . . . .
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 07 Jan 2022 at 8:21am |
had a bunch of those blocks on my property when i purchased it assuming from some old farm building. we laid a bunch of them down for a patio next to the house and used it for years.
Joined: 11 Sep 2009 Location: illinois Points: 90804 |
Posted: 07 Jan 2022 at 8:35am |
lot more strength in the wall if the blocks are STACKED with holes vertical.... might help for any leaks also as any water runs DOWN the hole to base.
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11401 |
Posted: 07 Jan 2022 at 9:40am |
Don't seem like it would be very warm, cold would go straight throught them walls
modirt
Joined: 18 Jul 2018 Location: Missouri Points: 9434 |
Posted: 07 Jan 2022 at 5:16pm |
We tore down a similar building a few years back. Was built in 1915....so lasted 100 years. They used tile like that for the load bearing walls in the basement and exterior, with brick veneer exterior. Interior walls plastered. Similar to how some have used cement blocks. Over the years, foundation part cracked and settled, so yes, during wet times when water table was up, you got some floor leaks running to the floor drains. There was an addition built in 1960. That one went to cement for foundation, then stacked cement blocks 3 stories high, with brick veneer. No cracks in the cement foundation in over 50 years. Most cement foundations crack now, but none there. Foundation was close to a foot thick. Can only conclude cement used then different that what they make now. But she is all gone now. I thought they would have to blast it apart. Not so. One enormous track hoe showed up and it came down like it wanted down.
DMiller
Posted: 07 Jan 2022 at 6:01pm |
What concrete was in these two houses was soft and easily demolished, sad there was ZERO reinforcement anything in either.
richashon
Posted: 08 Feb 2022 at 4:11pm |
What if there was a small crack on the outside of the house? Could a rat or other rodent get in and run inside the house walls in circles? That kind of material looks fragile. No way it could hold a heavy load. And if a large hole appeared because of some kind of accident, the whole wall would go down, like Jenga bricks. I always suggest everyone be extra cautious when examining property you’re interested in. Ideally, hire professionals like Building Inspections Perth.
Edited by richashon - 10 Feb 2022 at 1:50pm |
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6124 |
Posted: 08 Feb 2022 at 10:43pm |
There's a wall in my basement made out of similar clay block, but it's standing upright (as it should be) and it's NON LOAD BEARING... And the reason for standing it up on edge, is pretty simple: When on side, you have a front and back side supporting all the weight... the top and bottom support nothing, and there's no ends. When standing upright, you have the front and back sides, the right and left sides, all supporting vertical load... and the ends are open. Using it properly, one would build the wall with holes all vertical, and as you build, drop in reinforcement, and fill it with concrete, to tie it all together. Essentially, the clay is a form, and I believe (by the design of farm structures I've seen) the clay will, under moisture and soil pressure, soften enough at any edges where moisture comes in... and SEAL itself a bit. In horizontal, it's basically a wall built with stale potato chips... I've done demolition, built things, helped others with demo and building, moved some buildings and one house... along the way, I've seen some wierd stuff... This is definitely wierd stuff...
Jim.ME
Posted: 05 Sep 2022 at 6:01pm |
SPAM reported
KJCHRIS
Posted: 05 Sep 2022 at 7:16pm |
My grandparents farmhouse had a clay block basement put under it in late 40's. That house never had water come in or a crack in a wall or the floor up to when we tore it down in 2015.
