Crawler Wrench??
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Topic: Crawler Wrench??
    Posted: 04 Jun 2014 at 11:48pm
I got this wrench in a lot of Allis parts lately. There are traces of what seems to be Persian orange paint left and I was wondering if it was for an Allis Crawler?  It measures 5 3/8" across the flats
AusHD6 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AusHD6 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2014 at 4:37am
This big ring spanner fits the sprocket lock nut on an Allis Chalmers HD6 which off the top of my head has to be torqued up to 2100ft/pnds
Post Options Post Options   Thanks (0) Thanks(0)   Quote AusHD6 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2014 at 4:43am
Wouldn't be ale to get it over the sprocket shaft with that handle welded to it though???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2014 at 10:01am
The handle looks like it was factory made as part of the wrench. It doesn't look like a later addition.
It's certainly won't fit anything on my Allis wheel tractors!!LOL
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2014 at 10:05pm
I don't know the nut size is on the old AC offset discs with the oil bath bearings inside the axle tubes.But the old IH and JD discs I am more familiar with would use a wrench  like this. I know were there is a disc measure but it will not happen for a few days as I am committed to other things for a few days.
Ray
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2014 at 8:16am
I wonder if that is the wrench for the nut that holds the cylinder on a 6g on the nut for the dump cylinder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2014 at 8:20am
I don't now what I was thinking I was thinking there was a nut on the dump cylinder pin but I think there a big nut on the pin right below it.
