Crank lenght |
1947WC
Joined: 11 Dec 2015 Location: Wisconsin Points: 214 |
Topic: Crank lenghtPosted: 21 Oct 2019 at 12:26pm |
Sorry I meant the part inside that goes to the engine pully.
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2584 |
Posted: 21 Oct 2019 at 12:32pm |
It's a direct swap. Nothing is different other than the stroke. AaronSEIA
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8982 |
Posted: 21 Oct 2019 at 12:52pm |
I don't understand the question....
1947WC
Posted: 21 Oct 2019 at 1:16pm |
Sorry I meant the engine crank that starts the motor. It goes through the WIDE FRONT end. The one I put, in is to short.
SteveM C/IL
Posted: 21 Oct 2019 at 1:24pm |
Wide fronts have shaft through bolster at an angle so I'd guess its longer. You can build your own with a piece of round stock and some hole drilling...NOTE..the wide frt uses a chunk on crank end which the roll pin swivels in (like a ujoint) because of the angle..... shafts may be the same with that added chunk for length?
mdm1
Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2720 |
Posted: 21 Oct 2019 at 2:02pm |
Parts book shows them as the same.
1947WC
Posted: 21 Oct 2019 at 2:12pm |
Thanks Steve M C
