Crank lenght
1947WC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Topic: Crank lenght
    Posted: 21 Oct 2019 at 12:26pm
Sorry I meant the part inside that goes to the engine pully.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 12:32pm
It's a direct swap.  Nothing is different other than the stroke.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 12:52pm
I don't understand the question....
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 1:16pm
Sorry I meant the engine crank that starts the motor. It goes through the WIDE FRONT end. The one I put, in is to short.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 1:24pm
Wide fronts have shaft through bolster at an angle so I'd guess its longer. You can build your own with a piece of round stock and some hole drilling...NOTE..the wide frt uses a chunk on crank end which the roll pin swivels in (like a ujoint) because of the angle..... shafts may be the same with that added chunk for length?
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 2:02pm
Parts book shows them as the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 2:12pm
Thanks Steve M C
This page was generated in 0.217 seconds.
