Crank Grinding/In-Frame
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Topic: Crank Grinding/In-Frame
    Posted: 01 May 2010 at 6:20pm
Found this small poster in friends barn, going to have it framed. Wonder if anyone actually used this tool.
Chuck(ONT) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 6:26pm
Yes, I have actually seen one being used on a friends 50 Chevy. It was at a dealership in Canada.
Never take life too seriously.
Nobody gets out alive anyway!
1C 1 WD45 1 AC180
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 6:28pm
Neat poster but not going to do that in my engine . I would like to keep metal particle and grinding rock dust to a minimum.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 6:32pm
Back in the 1960's when I was racing stock cars I had a local garage grind a rod journal by only dropping the pan and lifting the car on his hoist.  I was racing Saturday and Sunday nights on different tracks. The rod went out on Saturday night and the fellow ground the journal on Sunday afternoon and I was able to run that night.  Bolts up so the grinder turns the flywheel from the starter ring gear at the same time as it grinds the journal.
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 6:36pm
We had one all set up on display last year at Hutchinson on a B motor that was on a test stand.  We didn't grind anything but it was a fun display.  I have to agree, I wouldn't want the grinding debris all over in the crankcase.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 6:46pm
  did you ever hear of cleaning  my dad had a crank turned in the 40,s  in a a 1936 plymouth  ran for years after that  also know where that unit is at can still be used
 talked to the shop owner not too long ago about this  he used it a couple years backas the motor  was too big too remove  in a costruction unit  also cheaper than removal
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 8:19pm
I agree with Norm, I bet you could flush all the debris out, well most of it! Back in the "old" day's I suspect engine tolerances were a littleless critical.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 9:13pm
As Norm noted, the feasibility of engine removal oftentimes dicated the method used for repair.  This was a very common method for dealing with engines in submarines, because removing the engine simply isn't an option.  Worked well, considering how funky it 'looks', and yes, hosing down the crankcase and pushing oil through the mains is highly recommended.
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 9:15pm
heavy equipment bores are often remaned in place.
This page was generated in 0.242 seconds.
