Crank for C
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: Crank for C
    Posted: 16 Apr 2011 at 1:49pm
I am going to try and make my own hand crank for my model C Allis.  What is the diameter?  What is the length and diameter of the pin that goes through the end?  I would think that making one would be cheaper than buying one...TIA Ted
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2011 at 2:15pm
 Mine is 12 1/2" from the end to the center of the first bend, then drops 6 1/2", then 4 1/4" for the handle. It's 3/4" shaft with a 5/16 x 1 1/2" pin that is 5/16" to center from the end of the crank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2011 at 5:21pm
Thanks Lonnie!!  That should do it!
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2011 at 5:30pm
   we have new cranks w/spinner  $40.00    good luck    1-800-254-3116 for ordering
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2011 at 6:30pm
There has been one on the local Craigslist forever.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2011 at 8:24pm
Eldon, what do you think he would take for it?  I wonder how much it would be to ship to La Crosse, WI  54601
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2011 at 8:58pm
Ted. there is a drawing for a B hand crank on Rod(NH) webpage with all the dimensions needed to make one.   Is the same for a C?           Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 4:58am
Tim, I can't find anything. Do you have a URL or something?
Thanks, Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 5:03am
Tim, I just did a search for a drawing for a hand crank for an Allis Chalmers B and found it.  According to the above from MNLonnie, they are not the same.  Thanks anyway...
