Craigslist find
Lanse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lanse Quote  Post ReplyReply Direct Link To This Post Topic: Craigslist find
    Posted: 29 Apr 2010 at 5:59pm
Not mine... But a nice running B with 3pt for $900, including a finish mower.
rich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rich Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 7:34pm
I called and # said out of service, disconnected
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 7:45pm
Guys, I think that is a C with a B front end under it. Look at the steering bellcrank. It is on top, going down to the front axle. Rear end looks pretty wide for a B too. Has the dished rear hubs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 8:04pm
Dream, it also has the notch in the rad shroud for the C, but is that a B adjustable arched front end? A better picture would help. And with the steering gear that way do you have to turn left to go right? LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 8:08pm
They must have switched something around down at the front axle to make it steer right..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 8:13pm
Charlie, I tried saving it and zooming in on it, but the resolution is so bad, I can't make it out. Looks like  a standard wishbone frontend to me.
Not sure about the steering. Seems like it would be backward to me. I know the B and C steering boxes were opposite. One right-handed, the other left-handed.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 9:21pm
I have a C with a B adjustable wide front. It doesn't steer backwards if you leave the steering arm pointing up. It's very easy to steer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 9:52pm
it is a C  tractor with a B front axle. Like Thad said, the C arm points up, leave it that way and the steering is fine. If you put the arm down like the B, then things are backward since the boxes are opposiite INSIDE.  Nice mower.. probalby easily worth $900 with that deck.
