Cracks at Torque Tube & PTO area WD45
Rod Yowell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod Yowell Quote  Post ReplyReply Direct Link To This Post Topic: Cracks at Torque Tube & PTO area WD45
    Posted: 12 Jun 2012 at 5:47pm
 I was cleaning the part of the torque tube where the PTO bolts to it underneath. I am having to replace the PTO assembly because it was broken by the fellow I got this tractor from while he was brush-hogging. I just noticed two slight cracks in the torque tube housing that are about 2 inches on each side of 1 bolt. The cracks go up into the housing about 1 to 2 inches and I believe they either connect or at least go toward each other. The rest of the bolts on the housing and torque tube are fine.
    My questions are these. 1. Are these slight cracks enough of a problem that I should replace the torque tube now?  2. Will the PTO housing just snap off again when I start up the PTO and engage a brushhog? 3. Will tightening the bolt down on the PTO housing cause this part of the torque tube to snap off? 4. Is this something that can be welded or fixed with a JB Weld type of product?
    Thanks for any suggestions or comments you guys might have.
Edited by Rod Yowell - 12 Jun 2012 at 6:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod Yowell Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 6:48pm
Edited by Rod Yowell - 12 Jun 2012 at 6:52pm
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 6:52pm
 Replace it, they are plentiful,  and cheap.  Buy one close enuf to drive to pickup.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 6:57pm
you will need to disassemble it to replace your intermediate gear anyway, just replace the whole works
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 7:10pm
Replace the housing.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 7:29pm
Yes I agree - replace the housing, I had one in my junk pile that had the same brake and
had been welded and broke again -- get rid of it now and be done with it!!
Mike56073 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 9:19pm
     Everbody is right!  You have to take it apart anyways to replace the gear.  If you don't replace the housing it'll either break or you'll constantly worry about it breaking.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 10:01pm
Rod, I sent you a private message.  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 10:53pm
Just like me,the cart before the horse.He already replaced the intermediate gear....and you don't have to split to do it.They are plentiful and I agree replacing is best but man what a lot of work. Not hard,just time consuming.You said you're not a mechanic but you will be when you overcome this tractor,and you can,step by step.Chin up and dig in!
 Chances are ole Rick has a complete,usable section that you can just swap in,and he will treat you right.
Edited by SteveM C/IL - 12 Jun 2012 at 10:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod Yowell Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 7:13am
Thanks to everyone for all the replies. I just knew I was going to have to replace the housing. I wanted someone to tell me what I was afraid of. I know your all right and I am going to bit the bullet and break the tractor and replace the torque tube. Rick I PM'd you back. Thanks again to all you guys. Your really great to help me out.
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 7:49am
I just wonder if they are breaking because of being loose. The three different 45's we have used in our baling I have had to tighten the PTO housing when I was prepping them for work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod Yowell Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 8:33am
Kevin,
         I don't know if they were loose because the guy I bought this tractor from said he broke the PTO during brush-hogging. But I will remember to check these bolts on a regular basis to make sure they don't work loose.  I only want to do this repair once. Thanks for the info.
Edited by Rod Yowell - 13 Jun 2012 at 8:34am
stu(ON) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 1:46pm
When you are remounting the PTO box to the torque tube, I encourage you to heed the instruction in the service manual regarding the clearance between the idler gear and intermediate gear.  I don't know how to measure for the 0.004" backlash, but if it is hard to engage the PTO, you will feel it and you need a second gasket.  I believe that the tolerances on these parts was fairly loose and it would not be unusual to find a tight fit when mixing and matching parts.  I know that I did and that a second gasket brought things back to the way it originally felt.  This could be one thing that puts pressure on the torque tube, intermediate gear and idler gear.
I also have spent too many hours repairing PTO damage incurred by brush hogging.  All my fault.
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 2:00pm
I dont think these tractors were designed for the torque of a heavy mower. I sure wouldnt use a very big one on my WD. Trev.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 2:13pm
Trevman, you are right.  They were designed for the rather steady load of a rotobaler, not the shock load of a brush hog.  I doubt that hogs even existed in 1948.   If you use a WD to actually hog brush, or even run over ant hills, you really want a slip clutch or use really soft shear bolts with the periphery scored.  The PTO is the weakest link; just too easily damaged.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 2:32pm
Help my  dad put pto on a WC  Instructions said if to tight it would whine , if to loose it will roar. Used that idea  for a many a year. Also !  Pulled  a  66 for year with a D/14 no trouble  , used bush hog  and twisted short shaft of pto . Took out and used 41/2 side grinder on splines and got it to work again . Put slipe clutch on .  To check slip clutch rev engine up  and drop foot clutch , you need to hear it slip  just a little.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod Yowell Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2012 at 7:37am
Well I picked up a 'new' torque tube housing and PTO gear box yesterday (along with a few other parts). So I am going to start on the splitting of my WD45 today. I will see if I am smart enough to do this repair or not. I let you guys know how it comes out. LOL
Socialism is the Philosophy of Failure, the Creed of Ignorance, and the Gospel of Envy
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2012 at 8:00am
Don't remember which end I blocked and which end I rolled but I unbolt frame rails from rearend and split trans off trq hsg,then pull trq hsg off clutch hsg. Take your time,be careful.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod Yowell Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2012 at 8:05am
Thanks Steve, I will.  That's the way I am going to do it also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2012 at 10:10am
Its just nuts, bolts, and time as a buddy of mine likes to say. If I was splitting a tractor, Id have someone with me to help, just stay safe, Trev.
This page was generated in 0.120 seconds.
