Cracked exhaust manifold 190 gas
Jamz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamz Quote  Post ReplyReply Direct Link To This Post Topic: Cracked exhaust manifold 190 gas
    Posted: 10 Apr 2017 at 3:28pm
I can not find a replacement exhaust manifold for my 190 gas, it appears they aren't available NOS, aftermarket, or used and from the sound of it, I wouldn't want one anyway because they always crack. One crack had been welded and didn't hold.. I think I can clamp a soft aluminum gasket around both cracks and install new manifold gaskets(readily available) and be OK.
Or, perhaps others in this situation have found better a solution ?
I would like to replace the intake manifold gaskets also because I think they're leaking and causing it to run rough after an hour or so of proper operating temperature....but I cannot find them anywhere.
Can anyone help me find them ?  It's an early 190,  sn# 1364 if that matters.
Thanks
Edited by Jamz - 10 Apr 2017 at 4:11pm
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 3:52pm
Do you have one? Are you wondering if you can fix one? What are we dealing with? We want to help you.
Edited by farmboy520 - 10 Apr 2017 at 3:53pm
Jamz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamz Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 4:16pm
Sorry Farmboy, I fat fingered and sent the post before writing it,
it should be updated now.
45 turboa- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 45 turboa- Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 4:22pm
I have one off a 180 gas I think it is the same i'll CK part # to be sure.
turbocharged
Jamz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamz Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 4:51pm
Part# on my cracked one is 4023626
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 5:18pm
They can be welded, but it takes a man that knows what he's doing. If your intake is not cracked they can be surfaced.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 8:17pm
What about one off a combine engine??? different OR same??? thanks; ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 8:43pm
Have a nos one for sale. Send me a PM if interested
Owner of Matt Scott LLC
http://www.mattscottllc.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 7:24am
A new A-C replacement manifold is probably different than the original. A-C took out some of the sharp bends in the runners to help keep the cracks from forming.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 10:28am
When I was looking for one last year, I found that there are 3 part numbers each superseding the previous one. I bought a nice properly welded used one and had it resurfaced before instalation which is a must in my opinion.
AndrewGubbels View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndrewGubbels Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 10:44am
The combine manifolds will work and as was stated earlier in multiple posts the later ac manifold was redesigned without allis chalmers written on the exhaust side. The later g gleaned and we also have a 1970 190xt gas with the later style. They do not have the issues breaking. Also definitely have it surfaced or be checking this. I like to do the exhaust and intake together bolted up so there is as little chance of a bind as possible.
Andy
Andrew Gubbels
Gubbels Restoration
Jamz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamz Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 5:59pm
Thanks guys, this is good info !   It may explain why ALL STATES parts catalog does
have an item(101486) that replaces OEM no. 74007652 and 74007653. No mention of my
4023626. However, the picture they have of that item definitely does not look like it would work, it has the outlet square in shape being off center while mine is a round threaded outlet that's centered. Maybe it's just the picture in their book that's wrong.
If anyone knows what part number(s) the newer ones are, I'd appreciate it ! Or if the one from the combine is the later style.... and if so, has the same part number.
This page was generated in 0.106 seconds.
