Cracked brake housing
John m View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John m Quote  Post ReplyReply Direct Link To This Post Topic: Cracked brake housing
    Posted: 06 Mar 2022 at 4:51pm
In the process of replacing the brakes on my 190xt. While cleaning the brake facing in the brake housing I see there is a small crack. It's about 3/4 inch long going from the center towards outside of housing. Should I look for a replacement housing? Opinions? Thanks John
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2022 at 6:33pm
There are thousands of them running with more cracks than that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John m Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2022 at 6:52pm
Thanks Doc. Parts should be here Tuesday, I'll start putting her back together. John
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2022 at 7:28pm
If you drill a small hole at the end of the crack, it won't get any worse...
Post Options Post Options   Thanks (0) Thanks(0)   Quote John m Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2022 at 7:59pm
Sounds good, thanks
This page was generated in 1.109 seconds.
