Crack vs. bad gasket in B engine
briwayjones View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote briwayjones Quote  Post ReplyReply Direct Link To This Post Topic: Crack vs. bad gasket in B engine
    Posted: 04 Jun 2010 at 3:23pm
There's a B I saw advertised that has coolant getting into the engine.  What are the chances it's an actual crack somewhere in the engine vs. just a bad gasket?
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2010 at 3:31pm
It is usually head gasket or "O" rings on sleeves. Head gasket is easy. "O" rings are a little harder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2010 at 3:34pm
Also could be freese plugs in top of engine rusted out, another easy fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2010 at 3:34pm
Or the often overlooked core plugs in the top of the head rusted out. The core plugs are a cheap easy fix.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2010 at 5:36pm
buy it at a price for the worse  . I bought a d14 and new it was a core plug the only promblem was the guy had liquid glassed the thing and the motor needed a complete overhaul.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2010 at 5:48pm
under the rocker arm, looks like this
This page was generated in 0.058 seconds.
