Coupler Bell Pivot Shaft Stuck
bendts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bendts Quote  Post ReplyReply Direct Link To This Post Topic: Coupler Bell Pivot Shaft Stuck
    Posted: 14 Sep 2020 at 3:57pm
This is the big 1"+ Pivot Shaft that is on the top - connects  Coupler to transmission housing.  This bugger is stuck and stuck good.  It was pushed to the right slightly at some point in the past - looks like it sheared or jammed the left side cotter pin in the hole.
I have tried pounding on it, heating slightly and pounding, pipe wrench... Nothing.
What would you do to loosen this thing up?
Do I need to heat the area up more that it slides into?
Not sure how much abuse the casting of the trans housing can take before i bust something good.
Edited by bendts - 14 Sep 2020 at 3:58pm
1960 D17 Gas # 28849
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2020 at 4:05pm
Is this on a Tractor ?
Steve A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2020 at 4:08pm
Things I'd try in increasing order: Soak it with ATF for a couple days, then spray with Kroil, PB Blaster, etc. Heat around it, cool the shaft with ice. Air chisel with a rounded end to vibrate it. One guy on here swears by applying beeswax when red hot. If none of that works I'd make a judgement call and torch the shaft apart, thinking easier to replace that than anything on the transmission, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bendts Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2020 at 4:37pm
Sorry yes.  on a D17 s1.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bendts Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2020 at 4:48pm
Will give that a go. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2020 at 4:58pm
If you have enough working room you could also try drilling bad side, tap with a smaller bolt and then use that to pull outward like a gear puller. Or weld a nut on it to pry/twist while tapping the better end.
