Couple of C Plow Questions...
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Topic: Couple of C Plow Questions...
    Posted: 11 Dec 2016 at 8:46am
Looking for a mounted plow for my boys C. The manual lift ones...how hard do they lift? Also, how much ground clearance is there under the moldboard? Would like to be able to trailer it to do gardens.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2016 at 9:01am
First, you'd be better off with a hydraulic lift and all the parts are much easier to find. It should have the clearance you need to go on and off a trailer easy.
Blake_AllisMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blake_AllisMan Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2016 at 2:45pm
PM sent
1941 C
1952 IB
1947 C
1955 WD45 SFW
1956 WD45 Diesel
1977 5020 4WD Serial Number 1
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2016 at 9:20am
Aaron, I have to agree with Paul.  Get a hyd lift.  A lot easier to find and a LOT EASIER to operate.  If I recall when I hand lifted a plow it was all I could do.  When the Hyd came out it was a dream come true.
I was pleased to plow with David Dickmyer's C at our plow day in May.  They are a fun tractor to plow with.  Since it is mounted can work into a corner easily.  As to putting them on you trailer you will have no problem.
If your rear wheels are not "loaded" you may want to get some wheel weights.
Don't forget to check e-bay.  They seem to have everything.
Have Fun
Good Luck!
Bill Long
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2016 at 9:24pm
I have a C hand lift, but the freight would be enormous from PA. On mine the brake lock on the right side was removed to give a path for clearance for the lift bar.
Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
This page was generated in 0.077 seconds.
