cost of machine shop work
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 8:33am
The linkage from carb to lever needs to be right distance. Some manuals explain some on the procedure. My Dad usually does this for us by bending the lever one way or another. To far one way it will surge like an oliver to far another it will be a super dog or no acceleration at all under a sudden load. Allis was legendary on the snappiness of there gov. just wish it was built a little heavier. Our D17 grenaded the gov. at 2400rpm then went on to ruin the gov gear and crank gear. I have heard of several others breaking the weights off.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 8:50am
I always go by the book on syncronizing the governor. Use an Allis manual cause the I&T manuals gets it backwards. It makes a difference.
Wink
I am a Russian Bot
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 9:03am
Lou call me. I might be able to help. 724-255-9904
  Shawn
Edited by XT in pa - 01 Feb 2012 at 10:00am
190XT,D17and 7045
Rod B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 11:02am
The main reason that a WD-45 governer acts different than the D-17 is simple.  It is SPRING RATE and the tension on the spring to start with.  Put a WD-45 spring in the D-17.  Set it to rated WD-45 RPM and see how the engine responds.
It is not the crankshaft weight or the the .36 ft/lb change in rolling torque on the main berrings.  That is a verry small percentage of a single horse power at rated speed.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 11:40am
I don't believe that's it. I've had engines where I've put different springs. I never put a 45 spring in a D17 but have put a 45 governor complete on a 45 with a D17 engine. I still say it's the weight difference in crank and probably flywheel although a 17 engine in a 45 with a 45 flywheel make no difference. The 45 engines has more snap.
Wink
I am a Russian Bot
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 12:30pm
for the pullers out there at a compression ratio of 11.1 static 10.5 effective intake closing at 86 degrees 150 cfm. the 2.475 main bearing at 3000 rpms has 18.73 ftlbs of drag the 3 inch bearing has 20.18
Edited by mlpankey - 01 Feb 2012 at 12:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 8:29pm
Get a nasty call from Fred Stevo? Machinist from out west my a$$
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 7:43am
The other day rod b made a comment on lowering rod journal size. Still playing with engine bearing friction droping 3/8 in the rod journal reduces a full 2 lbs off engines total friction. I guess them nascar boys are on to something when they go to the 1.88 rod journal
Edited by mlpankey - 02 Feb 2012 at 7:47am
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 7:54am
What the #&!! got this post off TRACK !!!!!
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 7:56am
It was invaded by a rocket scientist
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 8:02am
You mean bottle rocket scientist.
I was picking on the class clown about narrowing the rods in his engine build.  A narrow crankpin is stronger than a wide one, and if it matters the narrow berring has less drag.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 8:21am
Rod b the proper name is crank fillet radius. Some just know enough to aggitate . Narrowing rod without knowing the crank fillet radius is just loosing oil pressure unless your opening up the clearance to use a bent rod. Everything one chooses to do engine wise comes with gains and losses. Getting the most gain for the least drawbacks is when you start challenging material composition
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 8:38am
It's kinda funny ain't :•)
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 8:43am
That does it,AngryAngry I am never going to open up another post on here while drinking or eating!!!
,,, another darned  keyboard ruined and monitor sprayed with pepsi and spit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 9:56am
Oh no I agitated pankey.  Forgive me for I am sorry for I was only amuseing myself at his expense, which is verry easy to do.
LMAO that's funny.  I thought someone asked him to "self deport"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 10:20am
MORE !!!!!!!!!!!!!! MORE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! PLEASE !!!!!!!!!!!!!!!!!!!!!!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 11:22am
Edited by Lonn - 02 Feb 2012 at 11:23am
Wink
I am a Russian Bot
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 11:57am
Entertainment at its finest, this is!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 12:40pm
If I we're to deport rod your education would quit.yes as you pointed out I prefer non circular contours . I expect 500 word essay on this next like your Wisconsin friend does shortly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 3:20pm
Lou, I am starting to think you are a trouble maker,,Tongue
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 3:24pm
Seems to follow me around doesn't it, Butch!
Edited by LouSWPA - 02 Feb 2012 at 3:26pm
I am still confident of this;
Wait for the Lord;
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 5:00pm
Originally posted by LouSWPA LouSWPA wrote:
weld and re-machine thrust surface, reface journals and bearings for a WD-45 crank.....$540!
mag block, square deck surface and counter bore sleeve seats $700-800
 Heck , Lou, I 'll answer your question. You may live in an area where machine shops are all  doing hi quality, no compromise work.  And those prices are probably not out of line  for an established shop with well qualified machinists, using the most accurate  machines and tooling available.  You may not require that level of work for your application, my advice.... shop around, there is ALWAYS some one who WILL do any job CHEAPER.
 PS you really do know how to bring out the best of the peanut gallery ! And I think they should throw in an align bore,recondition the rods,  complete balance job, and all the head work, too.  LOL
