cost of machine shop work |
Page 12> |
| Author | |||||||||||||||||||||||||||||||||||||||||||||
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25548 |
Topic: cost of machine shop workPosted: 29 Jan 2012 at 5:07pm |
weld and re-machine thrust surface, reface journals and bearings for a WD-45 crank.....$540!
mag block, square deck surface and counter bore sleeve seats $700-800
I am still confident of this;
| Sponsored Links | |||||||||||||||||||||||||||||||||||||||||||||
CTuckerNWIL
Posted: 29 Jan 2012 at 5:14pm |
Time to look for a different engine. There are blocks out there that don't need anything but cleaned up. Find a running engine for $400 that doesn't have slop fore and aft in the crankshaft and you'ld be money ahead probably.
Does your block need that work, or is a salesman selling the job to ya? |
EricSWPA
Posted: 29 Jan 2012 at 5:16pm |
Thats pretty pricey on the crank i had a case crank welded and machined for 400 or so a year ago id think about buying a new crank from valu bilt at that price.
LouSWPA
Posted: 29 Jan 2012 at 5:40pm |
Charlie, I don't see the need in the mag check, that was the shop man's idea, but the deck is just barely out of spec and I vacillated back and forth on getting the deck squared.
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 29 Jan 2012 at 5:53pm |
2010 valu-bilt catalog
new crank WD45 $333.32 less bearings
reground with bearings $463.14
i could see spending extra money if your wanting it stroked but for that price you'd be better off using it as a core
david a
Some time the voc school will take on a project for the price of parts |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8982 |
Posted: 29 Jan 2012 at 11:06pm |
Lou! Ohio Orange has a Gleaner engine in the classifieds for 600 bucks.
I had my block decked a smidge.The ctr bores aren't quite on the same plane as the deck but close enough.I think in retrospect,I would have been ok to just put it back together but.... You can probably skip that too and be alright. I believe these old girls need to be way of before it matters. Old school thinking here.LOL Edited by SteveM C/IL - 29 Jan 2012 at 11:13pm |
DonDittmar
Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2517 |
Posted: 30 Jan 2012 at 10:51am |
Time to look for a new machine shop........IMO
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
Butch(OH)
Posted: 30 Jan 2012 at 11:12am |
His prices are not out of line. That type of work is out of consideration for any engine that has cheap replacement parts available. Big difference.
LouSWPA
Posted: 30 Jan 2012 at 11:36am |
Steve, I saw OO's post but axed the Gleaner engine idea as it would take finding some scarce parts (more money). I'm thinking like you, I don't believe it really needs decked.....torque the head to specs, run engine awhile, re-torque and I'll bet it'll still be running long after I've departed this earth!
LouSWPA
Posted: 30 Jan 2012 at 12:11pm |
Steve,
In line with your "old school" thinking, a couple of years ago a good friend and neighbor asked me to look at his Ford 600 (I think), as it had a strange sound. I determined it to be a rod bearing. dropped pan and pulled cap. bearing shot, crank journal scored some, with two spots where debris had been pounded into crank......'bout the size of eye of a sewing needle. So I tell buddy crank needs to come out, rebuilt, etc Now, ya gotta know "Bill", owner of tractor. Bill is an engineer, very intelligent, and not afraid to get his hands dirty. Bill is also not destitute, nor is he cheap, but, he delights in finding the most economical way of doing things. Bill doesn't want to pull the crank, wants to avoid the expense. So, I suggested an alternate plan, under protest. I used ultrafine files to dress the high ridge where the debris had been forced into the journal, and then polished the journal by hand with emery cloth and scotch-bright. Then, I discovered that I could get one bearing, rather than a whole set from NAPA (wife ran a NAPA store at the time), so I had wife get me .015, .020, and I think .030 bearings and I used plastigage to test fit each bearing, checking four places, 90 degrees apart on journal. .020 was closes I could get, sent the others back. lubed bearing, torqued cap, replaced pan fired it up. He worked that tractor hard for a season and a half before it grenaded!
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 30 Jan 2012 at 4:09pm |
One thing with putting a Gleaner engine in it it won't act like a 45 anymore. I'm talking about the snap that only a 45 has. It will run nice and have more power but something will be lost. That's just my thinking though. I did put one in Dad's old WC and it does sound sweet and runs sweet but the sound is different.
Wink I am a Russian Bot |
Dipstick In
Joined: 11 Sep 2009 Location: Remington, In. Points: 8602 |
Posted: 30 Jan 2012 at 4:18pm |
Lonn I wonder why that would be, a different cam grind or something? Still trying to learn cause Im wanting to use a combine motor in a build for a WD.
GregLawlerMinn
Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Posted: 30 Jan 2012 at 5:59pm |
Had my CE engine crank ground 0.020 U/S and the rods reconditioned (so would not need to shim the bearings) for $180. Tanked block, decked, new cam bushings installed, sleeves counterbored and front and rear seals installed for $250. Complete head rebuild for $400 (included 4 hardened steel inserts for the exhaust valves).
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
mlpankey
Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
Posted: 30 Jan 2012 at 7:49pm |
Just put it back together need nothing more than a flat file and lapping compound .smear grey loctite on low spots .fill radiator with two quarts of liquid silicon .oh you need a round file for mains. Wrap some aluminum foil to take up cam bearing clearance.roll the used rings in sand to rough edges and remove carbon or rust. Run it hard till she blows or idle it from barns to show
Lonn
Posted: 31 Jan 2012 at 7:06am |
Don't get me wrong. The Gleaner engine will be nice and a better engine. It's the lighter weight of the crank that gives the 45 it's snap. That's the only thing I can think of. A Wd won't have that same sound either because of the shorter stroke. The 45 IMO was made just right for what it did.
SteveM C/IL
Posted: 31 Jan 2012 at 8:57am |
That dog won't hunt Lonn.Larger mains ain't enough mass to change it plus its on center,not swinging. BUT....you are right about "not the same". My uncle had a 45 and D17ser4,both bought new,and the 17 was doggy.
mlpankey
Posted: 31 Jan 2012 at 9:46am |
I tend to see the d17 having more bearing speed friction from increased bearing size but the quality machine work not needing shims on a 17 engine probably cancells out the smaller bearing on the 45 block and the 17 center main thrust gives the advantage.
Lonn
Posted: 31 Jan 2012 at 10:15am |
You tell me why then. I've swapped cams, carbs, governor weights, etc. About everything but flywheel and crank. The 45 is distinct and I blame the crank. On center doesn't mean heavier weight can be turned up to speed as fast as a lighter weight. If it's heavier, to me at least, it still takes more effort to get it going. I'm not a mathematician though. Someone here should be able to show some figures.
mlpankey
Posted: 31 Jan 2012 at 11:50am |
when i get time i wil run the numbe
< name=my ="compute.">
KGood
Joined: 17 Nov 2009 Location: Logansport,IN Points: 955 |
Posted: 31 Jan 2012 at 12:50pm |
What about flywheel weight and diameter. The PD is alot heavyer than 3 disc hand clutch. Just by looking I think the 17 crank pully is bigger so it would be driving fan and gen. faster. Just all these things together makes a difference. I would only want the 17 crank for my tuggers though.
KGood
Posted: 31 Jan 2012 at 12:54pm |
By the way I was comparing the two different tractors. I know the gleaner engines we have got seem to have small manifolds.
SteveM C/IL
Posted: 31 Jan 2012 at 1:35pm |
to some degree you'd be right Lonn about larger mass on center takeing more energy to spin up but what KGood said about the PD clutch makes the most sense to me.I don't know if the large dia flwhl weighs more than the small heavy 45's but I think larger takes more energy than smaller of same wieght.Moment of inertia thing.High school physics was a long time ago.
As an aside,my 6th grade class went to Chicago Museum of Science and Industry. They had a large long round chunk of steel with a crank handle on the end.it was in a saddle riding on oil film.Took a lot of pull to make it turn but then you couln't stop it either. Mass,enertia,stored energy....kinda cool.
mlpankey
Posted: 31 Jan 2012 at 2:26pm |
actually the larger the diameter the flywheel is the less it can weigh to accomplish the same energy stored.
Lonn
Posted: 31 Jan 2012 at 3:01pm |
Push in the clutch on the D17 and compare it to a 45 even with the clutch fully engaged and still the 45 is a different animal. I believe it's got to be the crank and probably the flywheel. Dad used to say that his old 45 could keep pace with the D17. Now he never had both at the same time as he traded the 45 in on the 17. The WD45 is truly is a unique tractor. Actually amazing like few other tractors in my very prejudice one sided mind. LOL
mlpankey
Posted: 31 Jan 2012 at 5:19pm |
well i said i would so i did . A WD 45 with Lpg compression ratio has 3.16 ftlbs of crank bearing friction load . A d17 with 7.1 comp . ratio 3.28ftlbs of bearing friction load both were done at factory high idle.
SteveM C/IL
Posted: 01 Feb 2012 at 12:39am |
So Mitch! Are you saying the friction in the 17 is enough more to show up in "snap". Is that a total # from all brgs? If so .12 lb/ft doesn't sound like enough to notice.
Lonn
Posted: 01 Feb 2012 at 6:57am |
Doesn't sound like much to me either but what do I know. I do know that there is a difference between a 45 and 17 when it comes to engine reaction to load. I have put D17 pistons in a 45 and if I remember right it still had that snap. I'll have to go over to the owner of that tractor someday and give it a test run. It's my cousin's 45.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 01 Feb 2012 at 7:12am |
Well, pretty soon ole Fred should have his "in house" machine shop set up n' ready to roll, and everybody can bring their engines to the Fredster to get their machine work done. I'm bringing my little G engine down for a rebuild....
Edited by Steve in NJ - 01 Feb 2012 at 10:29am |
mlpankey
Posted: 01 Feb 2012 at 8:03am |
I think its more the horsepower increase and the ability to hold power that makes the govenor not feal as snappy after running program. It was interesting though to run the program on 1/2 inch difference in diameter and comp. ratio and engine rpm to see . If you have identical rpms and compression ratio the ftlbs go to the same on both bearing diameters and untill running the program at 1985 rpms on both i would have thought they would have been some difference due to the 1/2 inch in diameter difference. We also didnt take into account crank overlap which the d17 crank will clearly win that . I also didnt exceed the 1985 rpms or 7 to1 compression ratio nor did bearing design come into play but could run more hypothetical numbers if one wants to evaluate more rigid.
Page 12> |
