correct spark plugs for a B with a distributor
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: correct spark plugs for a B with a distributor
    Posted: 06 Sep 2010 at 8:38am
I would like to know what plugs and gap to use on a 6 volt B with a distributor?
countryguy828 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote countryguy828 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 8:40am
I used Autolite 295's in my CA with distriubtor as per reccomendation from Steve at B&B.
Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 9:11am
The 295's are a little bit hotter plug which work much better in worn engines. Some folks use the 303's for Distributor fired Tractors. They work fine also providing the engine is pretty fresh, where oil control is in check and compression is up to the norm.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 9:18am
ngk b6s
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 11:38am
I've tried the NGK B6S plugs in my machines also. They worked quite well. No fouling, and burned pretty nice....
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 11:56am
I goofed a b4 is the equivalent to a ac 45 or autolite 295 . the b6s is equivelent to the ac44 or autolite 303.
