Correct hyd. Fluid 715 backhoe
bleeds orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Topic: Correct hyd. Fluid 715 backhoe
    Posted: 22 Aug 2023 at 8:05pm
Is it ok to use the same hydraulic fluid as the stuff compatible to the 821 allis-chalmers hydraulic/transmission fluid that is used in my bigger 7000 series allis-chalmers tractors?
I'm not sure on correct hydraulic fluid for my 715 allis backhoe.
Thanks cory
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2023 at 11:16pm
Hyd Fluid - I use AW fluid m now the heavier grade 42  and if I have to add any later in year will go to the AW 32 .
  As the rear differential is made by FORD and has wet brakes , Universal Tractor Fluid , or equivalent  used there ,
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2023 at 7:09am
Is it ok if I have the stated hydraulic/transmission fluid in backhoe or should it be changed out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2023 at 9:41am
we use UTF in our CASE 530 hoe.... I dont see anything MAGIC about the 715 that would require other..
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2023 at 1:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2023 at 11:59am
Any oil should work as long as it's anti foam , anti wear additives . In fact a 10/30 engine oil will work . In my HD5G I got a couple drums of ATF that I used for the hydraulics and it worked fine for years of use .
 It's more important to check for moisture content in the oil no matter what section of the unit uses oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 1:47am
Thank you.
