corner post exhaust on 7000 series
nick121 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Topic: corner post exhaust on 7000 series
    Posted: 13 Dec 2020 at 2:10pm
Seen the odd post online where people have re routed the exhaust to the corner post. I have a 7045 i'm fixing up and needs a new stack.
Likely run a straight pipe but now wondering about running it along the cab for better visibility, anyone have any pics?  I'm hand with a welder so that's no prob for me
Still leaves the intake, not sure if it could be moves very easily
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2020 at 3:38pm
Would be easy to move intake. Just ditch the pre-cleaner. But I don't know if that's a good idea
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2020 at 6:12pm
Why would you want to move the intake ? Exhaust will be very easy, but then again - why ? As Allis had it very easy to see around
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2020 at 10:02pm
The correct size pre-cleaner can be mounted under the hood. Been there and dun that.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2020 at 7:08am
Guess it's all about the look you want, and what you want to look (at)!
My 7045 is our first and so far only "big" tractor. Even at the test drive, I thought holy crap, that's a lot to look at on the hood, everything so large in comparison to what I had. But, reality is it doesn't block the view of anything you need to see, and after a few days I really didn't think of it anymore.
Dang it all, next time I drive it, I'll probably be staring at the intake and exhaust again!
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2020 at 8:04am
I know where there's a 7080 with the corner exhaust, I'll try and get some pictures.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2020 at 8:19am
Went to an auction  a few years back with a 7000 with side exhaust, looked neat but didn't take any pictures.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2020 at 11:15am
I wonder if relocating the 7000 series exhaust to it’s right front corner of the cab, increases the decibel level for the operator inside the cab?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2020 at 12:37pm
I'd be making a framework that attached to the side frame and not the cab structure. Some sort of muffler would help keep the noise down and an exit elbow of some sort pointing the noise away from the cab would also be good.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2020 at 1:09pm
If they had a cummins conversion wouldn't they be more likely to get a cab corner exhaust.
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2020 at 4:17pm
I just checked on a price for a muffler for a 7060 and don't know how many days it will take to get over sticker shock.
BKarpel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BKarpel Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2020 at 5:17pm
Most new tractors with corner exhaust are doubled walled. They are mounted away from the cab on frame work. I would try to avoid cutting side panels! What is the price of a new muffler,Grandpa has one for a 7030 sitting in the corner of a milk house.
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2020 at 7:30pm
Here's a picture of a Forum members exhaust modification. Very nice job, hope it helps you.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2020 at 9:27pm
New Nelson muffler for 7010-7060 is $195, Stanley looks like around $100
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2020 at 5:10pm
Just getting to reading the replies, Thanks for the picture of that 7080, looks like a real nice job.
If I do go ahead with this I'll build a support to the frame rail, Not going to be attaching to the cab posts or cutting through any panels.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2020 at 6:17pm
If the stock muffler gives you sticker shock then check the price of a double walled one...... I'll just stick with the regular set up. I can see just fine. I surely wouldn't butcher any part of the tractor for something that really isn't a problem for me though that 7080 looks like it was done right. I wonder if that made a nice looking plug to cove the exhaust hole in the hood?
Edited by Lonn - 24 Dec 2020 at 6:19pm
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2020 at 6:21pm
That's a very good price for the Nelson mufflers!
Wink
I am a Russian Bot
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2020 at 8:06pm
 Muffler for my Deere was pushing $1000 some of the new CIH with the tree hugger crap are in the $10,000 neighborhood.
Throme sp? has decent prices on exhausts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2020 at 9:27pm
Edited by AC7060IL - 26 Dec 2020 at 9:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2020 at 7:25am
On a 1 to 10 scale,  that there is a 10 1/2.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2020 at 9:15am
Nice work on the 7080. I do like the looks of the original muffler as well. Makes it look mean. I think that chrome setup going thru the hood would be really cool. 😀
Edited by Ed (Ont) - 28 Dec 2020 at 8:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 7:16am
That is amazing! That whole tractor looks great
