Corn head grease |
Post Reply |
Author | |||
orange-is-power
Silver Level Joined: 04 Dec 2011 Location: Kentucky Points: 362 |
Posted: 23 Jun 2019 at 9:23am |
This may be a dumb question, but does one use corn head grease in just a regular grease gun? I bought a tube of it and a new grease gun to fill a gearbox and I couldn't seem to get the gun to prime up and start pumping it out. Just wondering. Thanks.
Sponsored Links | |||
Pat the Plumber CIL
Orange Level Joined: 11 Sep 2009 Location: Springfield,Il Points: 4657 |
Air lock , seems every new grease gun I buy I have problems getting them going . The old pne i have had for 30 years works the best . Have newer one for marine grease for jet ski and I have another in my storage unit for my electric eel . I dread when they run out and need a new tube . Very hard to get them going with a new tube.
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
Dave in il
Orange Level Joined: 22 Sep 2009 Location: Manville Il Points: 1748 |
What do you have to grease on an electric eel? Do you use the marine grease or dielectric?
AGCO My Allis Gleaner Company
Tim NH
Orange Level Access Joined: 16 Oct 2012 Location: Lancaster NH Points: 1059 |
My Lincoln has a fitting near the hose you can loosen and let air out. Other times I have held it upside down, pull the rod back and forth while pumping it.
Tim
TimNearFortWorth
Orange Level Joined: 12 Dec 2009 Points: 2014 |
Loosen the pump/handle end 4-5 turns and start greasing, when you feel resistance it is fully primed and you can spin the barrel back up and keep going as air is purged.
Some of the smaller corn head guns have a rotating handle on the end that you turn to inject the heavier grease. Never tried corn head grease in my regular guns, just use the old screw type that is likely 30+ years old.
tomNE
Orange Level Joined: 13 Sep 2009 Location: dorchester, ne Points: 1214 |
I use cornhead grease in reg guns. spin the tube loose a few round and start pumping. in rare cases, turn gun upside down and bang on the side of a would bench, but that's a rare circumstance!
AC from the start of my families farming career till the end!
Pat the Plumber CIL
I use regular grease on a bearing and a bushing on the sewer machine . I keep it in a storage unit closer to town so I keep a grease gun there . I use the marine grease on a jet ski I have. Don't like swapping tubes around so I have another grease gun for that one |
Ranse
Orange Level Joined: 11 Mar 2016 Location: Tennessee Points: 773 |
I used corn head grease in a grease gun. Put the whole tube in the gearbox on my rake, then changed it back to regular grease. Grease guns are a pain. I hate all of them. They work good for a little while, then the next thing you know nothing is coming out.
wekracer
Orange Level Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1587 |
For years we have used a Lincoln battery gun and I never had trouble with it. The batteries finally went bad a year or so ago and I replaced it with a Milwaukee 18V because we have converted to all Milwaukee battery tools. I think the worst trouble I’ve had with it was having to hold the trigger for about 10 cycles while it primed. I would recommend either gun if someone was considering one. Well worth the $$$
victoryallis
Orange Level Joined: 15 Apr 2010 Location: Ludington mi Points: 2851 |
If you own a hugger head you get accustomed to pumping corn head grease. I have a DeWalt cordless grease gun I run it through. I find cornhead grease more finicky than regular grease. We just slightly unscrew the cartridge to bleed out air.
FREEDGUY
Orange Level Access Joined: 15 Apr 2017 Location: South West Mich Points: 5391 |
You guys speak of corn head grease, is this a"generic" term of grease? We run a black 4/30 Gleaner head ourselves, but I was under the impression that C/H grease was a JD thing??
chaskaduo
Orange Level Joined: 26 Nov 2016 Location: Twin Cities Points: 5203 |
Like Teflon or polytetrafluoroethylene. Ones brand name one is what it is.
DiyDave
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50327 |
The generic term is thixotropic grease, IIRR...
Gary Burnett
Orange Level Access Joined: 11 Sep 2009 Location: Virginia Points: 2838 |
John Deere and New Holland sell grease in tubes labeled "Cornhead Grease" just bought some last week at the NH place.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77210 |
JD developed it in 1970 to seal up leaks in boxes that would not hold 90 wt gear lube... Regular grease you use in equipment / bushings / pins is called NGLI #2 ... if you want a thinner grade of grease you buy #1............ Corn Head Grease is #0 ... it is thinner to the point that it will run... but thicker than 90-140 gear lube.
victoryallis
I used CNH grease because it’s the cheaper than Agco. Deere is even more speedy. |
Eldon (WA)
Orange Level Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
I found a case (12) of JD grease on Ebay for $50.
ALLIS EXPRESS!
This year: |
JohnCO
Orange Level Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Pat, I'm very concerned about the welfare of your electric eel. It seems cruel to keep it in a storage container. Is it heated in the winter? You wouldn't want it to freeze. How you did you get a live eel from the ocean to Ill.? And Why the Hell do you have an Electric Eel anyway??? LOL
Allis Express participant |
TimCNY
Orange Level Joined: 15 Apr 2014 Location: Upstate NY Points: 1551 |
GREEN NEW EEL, silly man!!! All-electric renewable world, HERE WE COME!!! Why, I'm told it even powers next generation electric jetliners, two will do. And it replaces the need for coffee, that electricity-intensive climate-changing beverage of choice for millions - just grab on and you've got your jolt for the day.
chaskaduo
The Dream
100 Miles per Galleon Edited by chaskaduo - 25 Jun 2019 at 10:44am |
HoughMade
Orange Level Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 690 |
Am I the only one who pulls the rod out to the end so that the pusher is pulled out, then released, a few times? Sure it's spring loaded, but pulling it out and letting it squeeze back down a few times seems to always move things around. That always seems to get my gun pumping again.
1951 B
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11380 |
Hough, I do that, and / or, I bump the squeeze handle, hard, periodically as I'm screwing the top on, as well as hold down the bleeder fitting my gun has. Bleeder fitting doesn't seem to do it by itself, but ever since I started bumping the handle, it is primed readily.
Post Reply | |
