Cordless Frame Nailer |
Kurzy
Joined: 02 Nov 2009 Location: WSS, Montana Points: 808 |
Topic: Cordless Frame NailerPosted: 07 Dec 2019 at 8:01am |
Howdy, Looks like I am going to be the one building on my new land i purchased. Labor has gone out the roof in my thinking. So getting started now for spring building. Need to know about cordless frame nailers ? Sure nice without the hoses! They the way to go? Thanks Kurzy
plummerscarin
Posted: 07 Dec 2019 at 8:26am |
I have a Bostitch. Don't hate it but the igniter seems to be high maintenance. Get two batteries if you want to move along at a good pace.
omahagreg
Joined: 11 Sep 2009 Location: Omaha, Nebraska Points: 2809 |
Posted: 07 Dec 2019 at 9:55am |
I am a trim carpenter who had most of his tools stolen in late 2005! I looked into cordless for all, but they did not make some of the stuff I use in cordless so figured if I need a compressor they should all be air! That being said, where I work now the other guys share Pasload cordless trim guns. They are a real pain-at least when multiple users use them-never know if the fuel or the battery is the problem! I recommend you get one that only uses one source for power, as it will eliminate alot of frustration!
Greg Kroeker
1950 WD with wide front and Freeman trip loader |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35666 |
Posted: 07 Dec 2019 at 10:03am |
Tried a couple of Hoseless nailers in trim and framing/roofing, cared nothing for most, high maintenance, expensive cartridges, just clumsy to me, hose is close to enraging but can manage a length of hose more than trying to swap a cartridge hanging off a rafter or truss.
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9731 |
Posted: 07 Dec 2019 at 10:13am |
I have a few Dewalt battery powered trim guns. Very expensive and slow. I use them specifically for punch list work and not for production. If the gas/battery powered guns were any good and affordable to shoot we’d all be using them. A couple guys at work have went entirely cordless but end up going back to pneumatic starting with framing guns.
Just my humble opinion. |
thendrix
Joined: 04 Feb 2013 Location: Fairmount GA Points: 5175 |
Posted: 07 Dec 2019 at 12:29pm |
Got a Paslode. Don't hate it don't love it. It's handy to not have to drag a hose but sometimes you have to finish driving the nails up.
Edited by thendrix - 07 Dec 2019 at 1:38pm |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55276 |
Posted: 07 Dec 2019 at 7:00pm |
Has anyone tried the Ryobi 18 volt electric trim nailer? looks like it would be handy as a shirt pocket, fer tacking stuff together, till you can get a heavier nail or screw into it...
[TUBE]wZFKZnq9vSA[/TUBE] Edited by DiyDave - 07 Dec 2019 at 7:03pm |
Thad in AR.
Posted: 08 Dec 2019 at 5:37am |
A coworker uses the Royobi battery trim guns. A hot battery is a must. They seem good for the price. Homeowner grade. |
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Posted: 08 Dec 2019 at 6:10am |
In my opinion, cordless guns are IDEAL to carry into a house for repair/small trim projects ( trim guns ) . A cordless framing gun has it's place like nailing in "after-thought studs/backer boards or small yard barn framing projects. I would never dream of framing an entire house with a cordless gun . by the time you buy all of the fuel cells/spare batteries,you could buy a quality compressor and hoses. You can't inflate tires or run a blow gun to blow out tools with cordless guns
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25247 |
Posted: 08 Dec 2019 at 6:34am |
my thoughts.... There's a reason the guys who build houses for a living use air guns, well several. Aside from quick, efficient, easy to use they are CHEAP to run and WORK. Withstood the 'test of time'. if, IF, the airless guns WERE overall better, you'd see them at every jobsite and NO compressors.... Jay
Dave in PA
Joined: 13 Sep 2009 Location: Mars/Wexford PA Points: 2631 |
Posted: 08 Dec 2019 at 3:00pm |
I might have to say, it a lot depends on what you are "really" doing. If paying for labor, go cordless for some things, like in the air stuff. Go air for the production lower stuff. Far less maintenance on air tools than the cordless. As for me, I have both Paslode impulse trim and framing gun. Have air in framing, coil trim, trim, brad, staple, and so forth, to many to mention. I do have the Ryobi 18 ga. air stick as well. It is fantastic for my needs as well, with no maintenance or issues for about a year now, using it at least once a week. Great for a room of trim, and out the door!! BUT as said a fresh charged battery is a must.
Kurzy
Posted: 08 Dec 2019 at 4:28pm |
Howdy, Thank you all for the info on cordless frame nailers! Now that I have my answer could I use my 1 hp compressor or do you need one of those special compressors which look like a pancake or double tank jobs? Kurzy
DMiller
Posted: 08 Dec 2019 at 4:31pm |
Check the Volume on those pancake units and at what pressure, match or exeed that and good to go.
Thad in AR.
Posted: 08 Dec 2019 at 5:00pm |
It doesn’t take a big compressor unless you’re nailing down subfloor or roof decking a hundred miles an hour.
I run 2 framing guns off of a 1hp 4 gallon pancake. |
FREEDGUY
Posted: 08 Dec 2019 at 6:16pm |
Twin "torpedo" tanks, 1 1/2 HP minimum would suit you well (oil crankcase). The "pancakes" are oil-less and PROHIBITIVLEY LOUD !! Hitachi would be my choice (which I own/run) is available at Menards for less than $180 "here".
