Coolant??? |
Post Reply | Page <12 |
Allis dave
Orange Level Joined: 10 May 2012 Location: Northern IN Points: 2848 |
John Deere Cool Guard II says it prevents corrosion, cavitation, rusting, and scaling I'd guess it's similar to the Case IH antifreeze. I've notices Case IH hyd oil has a reddish tint to it which makes me wonder if they like to add red dye or something, while JD hyd oil and antifreeze looks more "normal"
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77687 |
the JD web site says it is a COMPLETE system and does not need addatives or filter..Says it is a 6 year USE mix.
Im sure JD does not make antifreeze... They have a contract with others.. Just tell them to leave out the RED DYE in the JD batch. Edited by steve(ill) - 06 Jan 2022 at 9:56am |
Orange Level Access Joined: 12 Sep 2009 Points: 19496 |
Deere has just made it more confusing by not having the same color of coolant. Oh well.
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7979 |
JD greene to match the undies
EXACTLY !!
CrestonM
Orange Level Joined: 08 Sep 2014 Location: Oklahoma Points: 8357 |
Please correct me if I’m wrong to make sure I’m understanding this.
All the Allis diesels I’ve been around (433, 649, 670) have had green antifreeze and coolant conditioner filters. Book says change antifreeze every 2 years, coolant conditioner filter every 600 hrs. My understanding was back then the green antifreeze was all they had. So if a person drained the antifreeze and switched to a more modern red heavy duty diesel antifreeze with the conditioner already mixed in it, one would not need the filter? But if one continues to use the green antifreeze then one should change the coolant and filter at the book suggested intervals? Thanks |
Smallfarm
Bronze Level Joined: 27 May 2021 Location: New Auburn, WI Points: 28 |
Thanks(1)
Creston, I'm with you on that analysis. Green=more maintenance and Red = Less. Like I said in my post if you don't need the filter with conditioner get a suitable substitute without chemicals. Nothing wrong with clean products and keeping them clean.
Brian Jasper co. Ia
Orange Level Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
In my days as a Ford tech, we got most of Ziegler Caterpillar’s 6.0 powered trucks. They started using their ELC coolant and I noticed they had almost no oil cooler and EGR cooler problems afterwards.
Greg(WI)
Bronze Level Joined: 12 Sep 2009 Location: Wisconsin Points: 126 |
Am looking at draining and replacing the coolant in my 175 . Going to go with the heavy duty pink antifreeze. Assuming that this would not matter with having an external circulating block heater but just wanted to get your opinions. Do you usually just drain at the radiator? Need to look in the book to see how many gallons I will need.
SteveM C/IL
You best drain every where possible and refill with water and drain again. You won't like the results of pink and green together. In other words,it needs totally flushed.
Ed (Ont)
Orange Level Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1217 |
Steve is right. Drain and refill with water. May be a good time to add some cleaner too. There are all sorts out there. Add some and fill with water. run and drain. Then go with whatever colour you choose.
Ed (Ont)
This has been a very informative thread. I have tried to stay informed on coolant but like a lot of things as you learn it gets even more confusing. These new coolants claim to be more environment friendly but when you read the label they are all still ethylene glycol based so kind of confused on that.
Ed (Ont)
Another question or maybe opinion. Does the red tend to leak more than green. Seems coolant leaks are more common now than before. Or is it just that the systems now are more complex and so many more places to leak. We are always chasing coolant leaks on diesel engines now.
Thanks(1)
Red seems to leak easier, yes.
