Coolant Filter/water temp sending unit |
cmalcom20 ![]() Bronze Level ![]() Joined: 26 Jun 2024 Location: Iowa Points: 10 |
![]() ![]() ![]() ![]() ![]() Posted: 16 May 2025 at 6:59pm |
Have a 76 7000, im going to drain and change coolant and need to put a new water temp sending unit in. How important would a coolant filter be to add? Also any help on replacing the sending unit, I have never attempted before
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21459 |
Drain the radiator and the block and use the proper "Heavy Duty diesel pre-mixed coolant which is pinkish in color. No water filter needed. Maybe flush system with clean water after draining the old coolant. Remove temp sender with a socket, extension and a 1/2" breaker bar.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8512 |
X 2 on the red antifreeze....
