Converting to spin-on oil filter on D17
Tom6070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom6070 Quote  Post ReplyReply Direct Link To This Post Topic: Converting to spin-on oil filter on D17
    Posted: 08 Jun 2019 at 7:46pm
Series one, D17 diesel with the old school , canister type oil filter . What's available to convert it to a spin-on filter? Are new bases for sale anywhere? Thanks, guys.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2019 at 8:01pm
Takes more than the base, block has to be modified and different oil pump. Search "full flow oiling" on here, there's a few good threads about it in detail.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom6070 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2019 at 8:38pm
Thanks, sounds like I better keep what I have.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2019 at 9:58pm
That is for an early model D17 with a gas engine.  Since yours is a diesel, you would only need to change the base to acommodate a spin on filter.  My question is: what benefit are you hoping to achieve?
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2019 at 10:43pm
The D19G 262 spin on oil filter base would bolt on directly
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2019 at 11:28pm
Yours is bypass system. Don't try using a full flow filter
Reread not a 230 so Bill's advice sounds right.
Edited by SteveM C/IL - 08 Jun 2019 at 11:31pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2019 at 7:18am
Sounds like block has been changed some time to the earlier block which used that type filter. No full flow filter for that block.     MAck
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2019 at 1:06pm
I think the AGCO number is PS100501 for the adapter. Not sure on filter number. Using a filter base from a newer D17 or D19 would be my preferred solution.
Edited by Nathan (SD) - 09 Jun 2019 at 5:56pm
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2019 at 1:24pm
The bypass system is still a bypass system unless you replumb the oil lines. A spin-on filter would be more convenient, but there wouldn't be enough back pressure and too much oil may get bypassed back to the crankcase.
Edited by DougS - 09 Jun 2019 at 1:26pm
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2019 at 2:49pm
The diesels did not use the bypass filter. The parts book shows the same oil pump for early and late  engines. Everyone is confusing the gas with the diesel.
The problem with the canister filters is that are difficult to get them to not leak.
wayne IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayne IA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 1:59am
We used the filter base for a series 4 D17 on our series 1 and worked fine, uses the same spin on filter as a 190 XT diesel, or a D21.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 9:04pm
Ah crap, I just reread this again. You have a completely different situation Tom, the conversion I was thinking applies to gas engines only. As mentioned above, there was an adapter available from AGCO at one time.
Edited by Bill_MN - 10 Jun 2019 at 9:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 11:05pm
The 45 diesel was bypass but the 262's are full flow.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2019 at 8:35am
All D17 Diesels are full flow oiling. you can use a spin-on filter base off C,CII gas or diesel and early F gas Gleaner combines or All D17,D19 Diesels, just use the filter that fits that filter base and get the mounting gasket that fits that base, your old base now has two O-rings just use the new gasket and NOT the two O-rings.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2019 at 9:23pm
Sounds like the block has been changed to a old 6b230 from Co-op, or old Gleaner combine, which used a filer like he is talking about. Even the Co-op D used the bypass filter.    MACK
