Converting B From Magneto To Distributor
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Topic: Converting B From Magneto To Distributor
    Posted: Yesterday at 3:43am
I found a deal on B but haven't been to look at it yet. The ad says it hasn't ran in two years. If the motor isn't locked up I will probably buy it. I don't know what year it is yet, but it has electric start and the wishbone front axle. My question is can it be converted to distributor ignition? I have two parts CA's so can I remove the magneto and install a distributor ignition from a CA? Thanks, Tim
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 5:37am
Yes the battery ignition (distributor) on a CA is an easy swap to your B to replace a magneto. My question to you is why? Unless your magneto is not working, I would keep it because you don’t even need a battery to crank start or pull start your tractor with the current setup. A battery ignition requires a good battery to run at all. Unless your intent is to replace the points & condenser with an electronic ignition module, there is NO advantage to the battery ignition over a magneto ignition.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:00am
Hasn't run in two years???  I'm sure there's a reason for that. If it isn't locked up, most likely the magneto is old and tired a a quality rebuild by a competent professional of the magneto will cost more than what you will probably pay for the B.
  How about swapping a distributer from one of your CA into the engine, get it running then saw the engine into one of the CAs. A CA is much more versatile than a B. You'll have a 4 speed transmission, Live PTO & Hydraulics, pin hitch or snap coupler and more.
 Don't get me wrong, a B is a good tractor for what it is, but a CA is much more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:38am
a little more detain... You dont just pull the mag off and stick the distributor on..... The DRIVE from the front gears to the distributor are different and need to be changed out.. Not hard, but a little more work..  You can buy a distributor that just plugs into the magneto drive lugs, but that is probably not on the CA.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:58am
My Dad raised mules so I grew up with mules; he used to say "When you got a good mule, you've really got sumthin', but when you got a bad mule, well, you got sumthin' there too!"
Same thing applies to magnetos Tongue
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:20am
I was thinking for the money, if the magneto was bad or weak since I already had the parts CA I could swap the distributor into the B. I have a Wood's L59 mower I could put on the B and give to my boy so he would have a good mowing tractor to use. I have three CA's here at home. One narrow front with a Wood's L306, one wide front with a loader, and one wide front I just purchased that I put a three point on so I could use my RM306 on. I agree the CA is a great little tractor but the B can be bought cheaply.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 35 minutes ago at 3:21pm
Yup. Your lowest cost option is to swap the the parts and be done with it.
Magnetos are great when they work, but they cost more to fix (at least for those of us who don't own a magnet charger).
Your mileage may vary Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 1 minutes ago at 3:55pm
i have "rebuilt" several mags over the last 20 years.. New point, condenser, coil, cleaning.....Still had problems with one after several years.. Bought a REBUILD from a vendon on this site... all the above PLUS recharge the magnet and new throw out springs for the impulse... WOW !!! What a difference !!... YEs, a GOOD REBUILDER is worth the money.. but not cheap..
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 9 minutes ago at 7:47pm
Cheap is where I'm at. I got the trailer ready to go today and charging the battery for the winch. I hope the B will make a nice mower for my boy and I don't have to do much to get it running. Sounds like the distributor swap is the way to go. Maybe a carburetor kit, clean the tank, new sediment bulb and NGK sparkplugs and it will start. This will be the first B I have ever owned. When I was younger there was a B that I should have bought and I have regretted not getting it. Going to makeup for it now. Thanks for the advice.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 11 minutes ago at 9:45am
I have a B with a magneto ('51 w/ original generator, starter and headlights).  A couple of years after I got it running after sitting still in my Dad's barn for a few years, the spark started getting weak.  I researched some "farmer tech" (doing what you need to to get it going) where you essentially run coil power through the original magneto, but in the end I got a rebuilt magneto from a guy in Illinois and it has worked spectacularly ever since.
1951 B
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 7 minutes ago at 9:49am
Do you know that the magneto is not working?  Maybe it is OK and might just need the points cleaned.  Many of my tractors have mags and I've found them to be very reliable.  Only ever had to have two rebuilt.
