Converting 78 units |
Matt4
Joined: 30 Apr 2020 Location: Albemarle NC Points: 6 |
Topic: Converting 78 unitsPosted: 30 Apr 2020 at 6:35pm |
I have a 4 row planter, 78 units on 333 frame set up for no till. I really like the planter,however I am not impressed with how well it closes the seed trench. My question is would it be feasible to convert it to common drive and engineer a better closing system?
I have several fertilize drives, transmissions, and jack shafts laying around. I know its not the same as the original common drive but I think it could work. Also would like a way to convert it to to a v wheel closing system. Could you expect better seed spacing with a common drive? Thanks for any help
tomstractorsandtoys
Posted: 30 Apr 2020 at 7:24pm |
Not to be smart but just buy a Deere 7000 and you will have what you want. You could even paint it orange.
I had an Allis 600 and Dad had a 333 and when I bought a Deere I was impressed with the improvement in my corn stands. Tom |
only AC orange
Joined: 06 Dec 2014 Location: Eastern Indiana Points: 609 |
Posted: 01 May 2020 at 6:20am |
What is your ground speed when planting? Those plate type planter units don't like to go fast (lot of skips if over about 3.5 mph).
Adam Stratton
Posted: 01 May 2020 at 10:19pm |
They made different style press/drive wheels that you might look into changing. It was also an option (I haven't seen many but we have a planter with them) to get the gauge wheels next to the openers (much like JDs) that would also help
Posted: 01 May 2020 at 11:20pm |
Maybe it would be feasible to lengthen the trailing arms to move the press wheel farther back and then graft a set of Deere type closing wheels ahead of the press wheel. Honestly, the MaxEmerge unit opens the ground and closes it up about as well as any row unit out there even 45 yrs after it was introduced to the farming world.
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3653 |
Posted: 03 May 2020 at 9:37pm |
This will fix your issue - look at a Sunflower grain drill - put these soil control strips on each opener or fabricate and weld two 1.5 by 12 inch strips to the v shaped opener guard on the front. The openers have a wide angle on the opener the soil is moved to far outward and lifted from the seed trench = this will fix the issue. We have built literally hundreds for all the old AC units.
Brian Jasper co. Ia
Posted: 04 May 2020 at 10:14am |
Do all of the 78 row units have a pair of small cover discs in front of the rear press wheel? I have a 330 with 78s set up like this. I have been planting beans and have been watching for areas that didn't cover well. So far it's doing a great job from what i'm seeing.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 04 May 2020 at 8:48pm |
JD7000 6-30's work well behind WD45's
Posted: 05 May 2020 at 12:28pm |
Small spring loaded covering discs were an OPTION for 78 series planter unit.
