Connecting rod hardening
jwbigbaddodge540hp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jwbigbaddodge540hp Quote  Post ReplyReply Direct Link To This Post Topic: Connecting rod hardening
    Posted: 04 Jan 2016 at 8:53pm
Who hardens connecting rods and what does it cost to have them done at what point do you need to have them harded, how much horse power and boost does it take to bend them?
Zaddison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zaddison Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2016 at 10:59pm
Can't really tell you but the people who can will need to know what rods.
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2016 at 6:09am
Heat treating an existing connecting rod is an exercise in futility, if you need heat treated rods, start from scratch and buy heat treated rods. Most tractor rods are not made of material that responds to strength enhancing heat treatment, meaning through hardening.
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2016 at 1:02pm
Assuming this is a diesel you are talking about?
Having the connecting rods hardened is like insurance on your car. Better to have it then have something happen and then wish you did. Along with solid push rods! to my knowledge you can only have the "cracked" rods heat treated. For re-sizing purposes after they are hardened. Some one correct me if i am wrong?  I would talked to Max Simpson at  simpson performance
mf440 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mf440 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2016 at 8:38pm
I talked to Max about hardening rods and he sugested that billit rods would be a better option if you are planing on making HP
200 allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2016 at 10:01pm
Max had hardened my rods for my 301. I had Bend one and slapped a sleeve.   But that was from some other issues do to timing. Friend of mine uses rods out of 7000s series and runs timing and 4200 rpm and aren't hardened and he is running road gear.
Larry W. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry W. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2016 at 11:08pm
Anytime I work with anything much above stock hp, I have the rods hardened, cheap insurance. Billet rods are nice, but a good hardened OEM rod will take a lot of punishment, pretty well proven over the years with allis superstocks. Good rod bolts are a must on higher hp as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jwbigbaddodge540hp Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2016 at 1:26am
thanks every one, this is for a 301 diesel engine I have a set of rods out of a 7010 Allis Chalmers that never sup a bearing and check out good, been magna flux for cracks, what does everyone do for rod bolts on here for there 301 talk to arp about them they don't have anything for the 301 Allis engines
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2016 at 4:22am
Just use new bolts from AGCO.
