Concrete crack filler |
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3074 |
Topic: Concrete crack fillerPosted: 06 Apr 2024 at 7:09am |
Five year old apron in front of my little shop has some small cracks in it. Any recommendations on some kind of filler? Thanks
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8165 |
Posted: 06 Apr 2024 at 7:17am |
Hydraulic Cement?
ACinSC
Posted: 06 Apr 2024 at 8:03am |
Thanks Lars, I see that can bought to fit in my caulk gun.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34424 |
Posted: 06 Apr 2024 at 12:05pm |
Are several Caulk type remediation products, just need to get some sort of filler INSIDE the crack anything of semi solid substance if any width to it. If hairline apply some of these caulk product lightly and allow to set even still showing crack, repeat process until fills and stays to surface.
I have used Concrete Crack Fill in a squeeze bottle with good luck, DAP has a similar product and the local concrete company I use utilizes DAP Concrete filler in a caulking tube.
ACinSC
Posted: 06 Apr 2024 at 1:07pm |
Thanks Dave!
DMiller
Posted: 06 Apr 2024 at 2:32pm |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3951 |
Posted: 17 Jul 2025 at 3:47pm |
the key thing is cleaning the crack , and may be etch it with muratic acid then apply any filler with the crack or area damp
DougG
Posted: 17 Jul 2025 at 5:15pm |
Just my opinion, and in the masonry business, you may take a 4 inch grinder with a diamond blade and - V - the cracks, then get a good amount of filler in there
