Concrete crack filler
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Concrete crack filler
    Posted: 06 Apr 2024 at 7:09am
Five year old apron in front of my little shop has some small cracks in it. Any recommendations on some kind of filler? Thanks
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2024 at 7:17am
Hydraulic Cement?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2024 at 8:03am
Thanks Lars, I see that can bought to fit in my caulk gun.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2024 at 12:05pm
Are several Caulk type remediation products, just need to get some sort of filler INSIDE the crack anything of semi solid substance if any width to it.  If hairline apply some of these caulk product lightly and allow to set even still showing crack, repeat process until fills and stays to surface.
I have used Concrete Crack Fill in a squeeze bottle with good luck, DAP has a similar product and the local concrete company I use utilizes DAP Concrete filler in a caulking tube.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2024 at 1:07pm
Thanks Dave!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2024 at 2:32pm
Thumbs Up
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2025 at 3:47pm
the  key thing is cleaning the crack ,  and may be etch it with muratic acid then apply any filler with the crack or area damp
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2025 at 5:15pm
Just my opinion, and in the masonry business, you may take a 4 inch grinder with a diamond blade and - V - the cracks, then get a good amount of filler in there
Vaterlemon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vaterlemon Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 9:05am
I had similar cracks in my shop floor and tried a few hardware store fillers, but they didn’t hold up too well over time. I ended up getting better, longer-lasting results after scheduling a quick consult through emersonproservices.com. They walked me through what would work best for the type of cracks I had and helped me avoid wasting more time and money on the wrong stuff.
Edited by Vaterlemon - 25 Nov 2025 at 8:56am
This page was generated in 0.119 seconds.
