Compression test wd45
Message Reverse Sort Order
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: Compression test wd45
    Posted: 15 Jan 2023 at 8:43pm
Originally posted by TomYaz TomYaz wrote:
...  I did new compression test with throttle up..  125-115-115-120 ...
That engine will run a long time yet.
I would address the ignition first.
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2023 at 4:56pm
The poor running was back in summer. Addressing it now so Its not about the cold weather. Fuel flow was the first thing I checked, its ok. Service the air cleaner every other year or so.  I did new compression test with throttle up..  125-115-115-120
Going to work on the carb, convert to electronic ignition, change the plugs.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2023 at 4:15pm
Plugs are black= over fueling/ lack of air. Is the air cleaner hooked up? When was the last time the air cleaner was serviced? It is winter, any moisture could be creating ice and restricting air flow. Had an Oliver that would run in the shop but not outside. Air cleaner was full of water
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2023 at 3:49pm
Originally posted by WF owner WF owner wrote:
Check the easy stuff first.
Before you tear into the carburetor, make sure your fuel flow is ok. Take the gas line off the carb and turn the gas on. Leave it on for a minimum of a full minute. Flow should stay steady. It's not uncommon to have foreign matter built up in the inlet of the sediment bowl, restricting the flow.
Thats fine, have a inline filter.
Debris plugging the tank outlet could still be your problem. I would definitely take the gas line off the carburetor and check the flow. It wouldn't surprise me if it slows drastically after 30 seconds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2023 at 1:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2023 at 7:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2023 at 12:20am
Originally posted by jvin248 jvin248 wrote:
Has the tractor been sitting a long time so rings got stiff?
Fuel restriction is the most common for that scenario.
Check the spark plugs against symptom photos.
No tractor has not been sitting.  Yes I think its a carb problem. Plugs need replaced.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2023 at 12:19am
Yeah,
I dont think the dieing has anything to do with compression, I just decided to check compression anyway becasue the tractor runs poorly even before the the dieing started.
Going to re-check the compression.
Thanks, know I can always get good insights here.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2023 at 11:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2023 at 10:29pm
Even if it actually has only 80 psi it shouldn't die when you rev it up if everything else is in order (carb, ignition).  Hard starting and low power, yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2023 at 7:27pm
Re-test with throttle wide open.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2023 at 7:17pm
Throttle WIDE OPEN ?? with a battery charger on the battery ??? pretty poor....125 psi is spec.
Throttle needs to be wide open to do a compression test?  Wasnt aware of that...
Battery was charged good, no problem cranking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2023 at 7:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2023 at 7:08pm
gasser
Dies when try to put past idle...probably bad carb.
Anyhoo thought I'd do a compression test
From radiator to the seat. - 80psi-80-80-90.  Did when tractor was ice cold. How does that rate?
Plugs black.
