Compression test wd45 |
| Author | ||
TomYaz
Topic: Compression test wd45Posted: 14 Jan 2023 at 7:08pm |
gasser Dies when try to put past idle...probably bad carb. Anyhoo thought I'd do a compression test From radiator to the seat. - 80psi-80-80-90. Did when tractor was ice cold. How does that rate? Plugs black. |
| Sponsored Links | ||
Posted: 14 Jan 2023 at 7:14pm |
Throttle WIDE OPEN ?? with a battery charger on the battery ??? pretty poor....125 psi is spec.
TomYaz
Posted: 14 Jan 2023 at 7:17pm |
Throttle needs to be wide open to do a compression test? Wasnt aware of that... Battery was charged good, no problem cranking. |
Posted: 14 Jan 2023 at 7:27pm |
Re-test with throttle wide open.
Les Kerf
Posted: 14 Jan 2023 at 10:29pm |
Even if it actually has only 80 psi it shouldn't die when you rev it up if everything else is in order (carb, ignition). Hard starting and low power, yes.
jvin248
Posted: 14 Jan 2023 at 11:11pm |
. Has the tractor been sitting a long time so rings got stiff? Fuel restriction is the most common for that scenario. Check the spark plugs against symptom photos. .
TomYaz
Posted: 15 Jan 2023 at 12:19am |
Yeah,
I dont think the dieing has anything to do with compression, I just decided to check compression anyway becasue the tractor runs poorly even before the the dieing started. Going to re-check the compression. Thanks, know I can always get good insights here.
TomYaz
Posted: 15 Jan 2023 at 12:20am |
No tractor has not been sitting. Yes I think its a carb problem. Plugs need replaced.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5180 |
Posted: 15 Jan 2023 at 7:00am |
Check the easy stuff first.
Before you tear into the carburetor, make sure your fuel flow is ok. Take the gas line off the carb and turn the gas on. Leave it on for a minimum of a full minute. Flow should stay steady. It's not uncommon to have foreign matter built up in the inlet of the sediment bowl, restricting the flow.
TomYaz
Posted: 15 Jan 2023 at 1:51pm |
Thats fine, have a inline filter.
WF owner
Posted: 15 Jan 2023 at 3:49pm |
Debris plugging the tank outlet could still be your problem. I would definitely take the gas line off the carburetor and check the flow. It wouldn't surprise me if it slows drastically after 30 seconds.
Boss Man
Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
Posted: 15 Jan 2023 at 4:15pm |
Plugs are black= over fueling/ lack of air. Is the air cleaner hooked up? When was the last time the air cleaner was serviced? It is winter, any moisture could be creating ice and restricting air flow. Had an Oliver that would run in the shop but not outside. Air cleaner was full of water
TomYaz
Posted: 15 Jan 2023 at 4:56pm |
The poor running was back in summer. Addressing it now so Its not about the cold weather. Fuel flow was the first thing I checked, its ok. Service the air cleaner every other year or so. I did new compression test with throttle up.. 125-115-115-120
Going to work on the carb, convert to electronic ignition, change the plugs. |
Les Kerf
Posted: 15 Jan 2023 at 8:43pm |
That engine will run a long time yet. I would address the ignition first. |
