Completely frustrated in Kansas!
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Topic: Completely frustrated in Kansas!
    Posted: 04 Apr 2011 at 3:41pm
I am trying to remove old sleeves from my 44C. I have tried several things:
1. use a hammer and a 2x4 to try to knock them loose. (yes, John, I got a bigger hammer!)
2. put a piece of wood on each side of the camshaft and against the bottom of the sleeve and used a chain wrapped around the block and attached to a floor jack to try to push the sleeves out.
These are 3 3/8 inch sleeves that I do not believe have been removed since they were installed at the factory.
Should I heat them with a torch, just keep hammering or what!
It's a good thing I Love Allis Chalmers or I would already have parted this one out! lol
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 3:48pm
If you aren't trying to save the sleeves, run a couple vertical weld beads up the inside. When the weld cools it will shrink the sleeves. If you want to save the sleeves some rust solvent like Kroil or a half and half mix of acetone and ATF might work.
Gerald J.
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 3:56pm
they make this great thing called a sleeve puller lol i had to use one on my wd45
everett048 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 4:07pm
Make a sleeve puller makes the job so easy,used my home made 1 several times on A,s
B,S and WC,s and also M crawlers  not had a sleeve i couldn't move yet, even left over night  wound right up sleeve still came up made it out of 1 inch unf stock threaded bar made several discs for bottom of sleeve, 8 inch round pipe on top 7/16 thick,a plate on top and a roller bearing and washer and wind away.If they don't move then wind up real tight then hit block with a club hammer and a piece of hard wood.That will shock it free.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 7:15pm
I turned a piece of 3/4 inch steel a touch smaller than the the OD of the sleeve, then turned a shot step on it to fit the bore. I had drilled a hole in the center for all thread but didn't use it. Put the block upside down on 4x4s on a solid concrete floor. Put you slug in the back side of one sleeve and strike smartly with 3lb or larger hammer, I had a block of Oak between the hammer and the slug. If the sleeves are stuck you can't get enough shock to remove with the engine on a stand or hanging somewhere.
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 8:02pm
This is an important point.  When you are beating, it must be SOLID!  We beat the sleeves out of a little Allis engine, and were trying with it just hanging on the engine stand.  Nothing.  Braced it up with some solid 4x4's to the cement floor and a few good whacks with a BIG hammer later and they were out, pistons and sleeves.  Had to make a press to get the pistons out of the sleeves.
Good luck!
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
48AC/WD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 48AC/WD Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 8:47pm
Get a sleeve puller, it comes out straight, and it makes it a helluva lot easier.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 10:00pm
Miles, I'll loan you the one I used to pull the B sleeve.  It's crude but effective and I didn't have to get a bigger hammer.
When I saw your headline I thought it was a country song!
Allis Express participant
