COMPLETE REPLACEMENT SEAT
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Topic: COMPLETE REPLACEMENT SEAT
    Posted: 27 Nov 2010 at 10:46am
 HELLO
 I AM LOOKING FOR A REPLACEMENT SEAT. THE SEAT IS ON A OLD 190XT, THE SEAT ADJUSTER HAS THE 1/2 ROUND NOTCHES ON EACH SIDE OF THE RAIL TRACKS WITH THE U- SHAPED ADJUSTER BAR BETWEEN YOUR LEGS, YOU LIFT IT TO RAISE AND LOWER THE SEAT. THE SEAT MOUNTS TO THE SEAT FRAME WITH A PIN WHICH GOES THROUGH 2 ROUND TUBES (THE TUBES ARE ABOUT 2 OR 3" LONG) WHICH ARE  MOUNTED TO THE SEAT PAN . I WANT A COMPLETE SEAT(PAN & CUSHION) OEM WOULD  BE WAY TO EXPENSIVE. WANT  AFTERMARKET . ANY ITEM # OR PART# WOULD VERY HELPFUL  THANKS THAD
chris jarosz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chris jarosz Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 2:14pm
Hy-Capacity makes one, black with fold up arm rests, and all you have to do is pull that rod out where it swivels and slide it through the new seat.  Thats what I put on my 190 and wors very well, even though you sit a little too straight at times, but there is "u" cut out for the gear shifter.  Cost was I think $200 maybe less, I cant remember but has frame and coushins ready to mount.
