Common failure modes: W-series starter |
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6089 |
Topic: Common failure modes: W-series starterPosted: 23 May 2010 at 10:26pm |
Hi All!
One thing I noticed on this WD that I'm working on... is that it cranks really slow, takes lots of current to roll it over. I've rolled it by hand many times, doesn't seem that hard. I'm pretty sure there's something amiss in this starter. It's stock 6v from what I can tell... Are they series or shunt wound? Are there any failure conditions or alignment situations that typically yield this result? |
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 23 May 2010 at 10:40pm |
Here is a short list of places to checkout-or do to your WD, Put 1 "O" battery cables on it and clean the posts on the starter battery and the ground where it bolts to tractor. remove the starter switch and clean the post on starter. Lots of starters are rebuild that are not bad because of other things are wrong. Don
DaveKamp
Posted: 23 May 2010 at 11:53pm |
Actually, Don, I've got incredible current flow. I used 3/0 cable, direct bolted to the starter switch, the other bolted to a wire-brushed bolt on the block, and had it connected to an 8D battery with 6' of 3/0 welding cable... hence why I asked about failure modes for the starter. I thought that with 12v/1100A on tap, and a 5.8v drop on cranking was a pretty indicative of some other problem...
When the end bushings or bearings are worn, do they drag that bad (I wouldn't think so)... or, if it's series-wound, is it a quartet of brushes, where armature feed is on one pair, while field is on the other... or perhaps shunt, and I have a failed winding? Is the WD starter, the same as a B starter? |
Gerald J.
Posted: 24 May 2010 at 1:29am |
Starters are series motors. Never shunt, though some recent geared starters are permanent magnet field types.
I had worn bearings in the starter on an 8N that with new bearings and brushes it cranked very good. Remember the magnetic field pulls the armature to the pole pieces to drag more than you can detect by spinning it by hand. And the side thrust from cranking can also shove the armature over, sometimes by bending the armature shaft. If there are four brushes, thats a bigger starter than for a WD, usually there are only two field poles, so when there are four brushes they are in pairs edge to edge on a wide commutator. And that's a BIG starter. Gerald J. |
M Diesel
Joined: 26 Feb 2010 Location: Las Vegas Points: 128 |
Posted: 24 May 2010 at 1:36am |
Passing along some background info... The drag problem can be very severe. Bad bearings will let the armature drag against the field coils. Field windings are mounted on the case and fed directly, not through the brushes. Armature windings are wired in parallel, and put the main current through the brushes. Starters also like to burn commutator contacts if stalled, particularly if over sized cables are used.
Bearings, brushes, bad internal wiring contacts, shorted coils are all problems. Worn commutator contacts let the mica separators poke up and lift the brushes. Older starters also suffer from solder joints gone bad at the connection between the commutator pads and the armature coils. This makes them turn slow for no apparent reason. The main difference in starter models is nose piece, rotation, number of brushes and the type of bearings. Most of the cases of that time period are the same. There were really only a few basic models. |
Brian Jasper co. Ia
Posted: 24 May 2010 at 4:47am |
3 ga cables are not enough. You need to go up to 0 ga. It will always crank slowly and act like the battery is run down if you don't.
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
Posted: 24 May 2010 at 5:42am |
Dave, the advice above really separates slow cranking speed into two categories: current transmission to the starter motor and physicial problems inside the starter motor. If you have attended to all the current transmission needs, then the starter motor itself needs attention. Assuming that 3/0 cable is lighter than 1/0, I'd switch cables and make sure that you have a solid ground from the starter motor to the tractor - see if that cures the problem. Are you sure that you have a good starter motor switch? If all of these are taken care of, it's probably time for a rebuild on the motor. Do you have another similar motor that you know works well that could be switched into your WD? Good luck - starter problems can be really frustrating!
WC, CA, D14, WD45
DaveKamp
Posted: 24 May 2010 at 5:46am |
Thanks for the tips, guys- just what I was looking for... I suspected that far-end drag was causing the shunt field to draw intense current, and that looks like the case.
Brian/Dave- there's a difference between 3 gauge, and 3/0. 3/0 is two steps larger than 0... it's 000 gauge... darned near a half-inch in diameter. http://en.wikipedia.org/wiki/American_wire_gauge My 'bump-start cart' consists of an 8D battery on a rubber-tired 2-wheel'd cart, with 3/0 cable. When there's lots of vehicles and machines around, it's always easier to roll the hand-cart into position and clamp on some really big cables. Edited by DaveKamp - 24 May 2010 at 5:49am |
Dave(inMA)
Posted: 24 May 2010 at 5:59am |
Gee Dave, I think your cable is big enough! Have you eliminated the starter switch from the mix? Odd as it sounds......it might be contributing to the problem, though the current drain you mention would say not. Sounds like it's time to get inside that starter!
WC, CA, D14, WD45
Posted: 24 May 2010 at 6:33am |
I've always been partial to the Delco-Remy WD/WD45 starters with the "center" armature brg.....many don't have it and they should for best cranking performance.
DaveKamp
Posted: 24 May 2010 at 6:48am |
Good morning, Doctor!
So how are those configured internally? Is the earlier version carrying a bearing at the bendix end, and a bushing at the brushes? |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42035 |
Posted: 24 May 2010 at 7:48am |
I have found most starter problems , if not the wire being bad is the end plate bushing. It takes a lot of load and wears allowing the arm to drag on fields. That robs the power from turning.
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
I changer the starter bearings in my D-10 and it made a big difference, they are not that hard to change. The bendix end can be driven out and the other just run a tap it then screw a bolt in and pull it, or put a bushing on the bolt and turn the bolt pulling the bearing.
Dusty
Posted: 24 May 2010 at 11:56am |
Center brg is a bushing on a disc that is sandwiched between the nose cone and the field coil body. Three bushings...armature end, center and bendix end. Keeps the armature from flexing and dragging on the field coil shoes. I thought all WD45 gassers had to have it to be able to start on 6 volts.
Ron(WA)
Joined: 11 Sep 2009 Location: Bellevue, WA Points: 283 |
Posted: 24 May 2010 at 12:52pm |
Here's what I did to solve the same problem you have: First I cleaned and lubricated all bearing surfaces, and when that only helped a little, I did what the experts recommended. That is, I cleaned out the spaces between the brush contacts on the rotor with a hack saw blade to remove the insulation and crude that builds a slight bump in the rotor where the brushes ride and often causes them to lose contact with the rotor and thus result in inefficiencies there. With good brushes and good springs to maintain this contact, the starter works like new. Over many years of use, the rotor surface pads will wear and the insulation between each pad does not, resulting in a contact problem.
Ron(WA)
Posted: 24 May 2010 at 1:13pm |
The word I was searching for was commutator. Use a hacksaw to file off a bit of the insulation dividers between the contact pads on the commutator so they are below the level of the pads.
DaveKamp
Posted: 24 May 2010 at 1:39pm |
Hmmm... great info, guys! Looks like when I get home, I'll be dippin' the carb and yankin' the starter. Think I'll pull off the tank at the same time (better starter clearance?) fill it with some bolts, and foam-rubber it into the tumber to clean the varnish and rust out. Thanks!
Gerald J.
Posted: 24 May 2010 at 10:39pm |
A good automotive electric shop will turn the commutator and cut back the mica before fitting new brushes and bushings. And do it at a cost not worth wrecking the commutator learning how to do it without damaging that commutator.
Gerald J. |
Bill_MN
Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Posted: 24 May 2010 at 11:28pm |
well looks like most everything's been covered for ya, i rebuilt the delco starter on my WD and it is not a difficult job. a good cleaning, and new bushings and brushes and starter switch can do wonders...the delco starter for the WD has four brushes, four field coils, and is series wound as you described above, mine worked pretty good but it really pops off now, i would definitely use 0 ga. battery cables as a 6v starter draws twice the amps as a 12v starter
DaveKamp
Posted: 25 May 2010 at 6:41am |
Pulled it out yesterday afternoon. One look at the drive Bendix, it was clear that someone had just had it rebuilt... to call it 'pristine' is a total understatement. I only had a few minutes, so I dropped it off at a local rebuild shop, then took my son to his baseball game. Shop owner (a local friend) said that it was clearly suffering an improper connection in the last rebuild. Gonna have him put a new switch in, too.
DaveKamp
Posted: 26 May 2010 at 12:50am |
Well, I got it back... worked late at the office tonight, but took a few minutes to put it in. It cranks better, but still not great... My D17 cranks much better, as does my '48 B. Turning it by hand isn't too hard... so I'm not sure why it's so 'cranky', but it certainly is. I'll look into it more deeply tomorrow.
DaveKamp
Posted: 26 May 2010 at 10:25pm |
Got it all set up... cleaned some of the paint off the housing (better ground), and mounted a 12v battery and short 00 cables, changed the coil, set it up for negative-ground, and it really romps now.
Now... what to do about the generator cutout... |
