combines
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2017 at 7:10am
I can still get most anything for the JD 7720. SOme in stock, some come in a day or 2. You can't expect any color dealer to stock every part for 50 years worth of combines.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2017 at 7:25am
I currently own a deere combine, I have had an E in the past -- 100% easier to fix than this deere. belts are out in the open not buried under the cab. Ran the 300-410-510 maseys in the past. I you buy the massey with both heads, be advised it needs to be the quick attach system for the heads. They are a super pain in the bu-- to change heads if they are the older non quick attach version.
Rick143 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick143 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2017 at 7:49pm
I appreciate all the suggestions it really is giving me something to think about. I have really learned a lot.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2017 at 12:48am
I vote for the Gleaner, parts are not hard to get, just gotta know where to find them.
The F is a little bigger and had the longest production run of any Gleaner (Between F, F2, F3 it went from 1968 to 1987) so parts are easy to find. Plus, its the smallest unit that you can get with a hydro.
Nothing wrong with the E though.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
