Combine + Grain cart = TRIBINE |
Thanks(1)
Topic: Combine + Grain cart = TRIBINEPosted: 3 hours 48 minutes ago at 7:16pm |
Around the year of 1997, a man from Logansport, Indiana had an idea to increase harvesting capacity and decrease harvesting labor requirements. His concept was basically a combine that pulled a 1,000 bushel hopper directly behind it. The machine was articulated to be able to steer, where the tail of the harvester connected to the front of the 1000 bushel cart. As I understand it, from 1997 to around 2012, he built three prototype machines. Each new machine (I'm sure) incorporated new ideas and benefits to his dream futuristic combine. The goal was to have 1,000 bushels in the hopper and unload into a semi-trailer in 2 minutes and then right back to harvesting. This concept harvester eliminated a tractor, 350 bushel dump cart and an operator, to catch grain on-the-go and then dump into the semi trailer. I first became aware of it in late 2012 or early 2013, when he had just built the fourth prototype machine, using a Gleaner S-77 combine platform !! Man, I was all in over this !!!!! The most radical design change in harvesting since WW2 (according to him) was now working in fields of wheat, corn and soybeans and it was a GLEANER platform he chose to build his concept machine with !! I know little to nothing about the three previous proto's, but by now the TRIBINE had large drive tires in all four corners and was true 4-wheel drive. The steering was mainly articulated at the tail of the harvestor and front of the grain cart. It also had crab steer at each of the four king pins (for getting close to a truck) and compound steering (for sharper turns on the end of the fields). Well, apparently the GLEANER platform wasn't going to cut it capacity wise, as a Class 7. I'm sure he was getting lots of interested parties calling him and suggesting what it would take for them to purchase one of his new harvesters. So, from 2013 with GLEANER S-77 (at 370 HP) to a totally new design by 2016, with a 38 inch diameter axial rotor with TWO engines, totaling around 650 HP !! Well, the other machinery manufacturers were watching and re-thinking their position in the harvesting markets as the TRIBINE kept morphing itself into a larger and different machine. Today, everyone's unloader system is about double the BPM, shortening unload time, and grain tank capacity is also larger. Many of the large grain carts you can buy now are waaay more than 1,000 bushels and 1500 bushels is becoming more common every season. Where am I going with this ?? Think about the hundreds of farm equipment manufacturers from 100 or more years ago, who didn't make it. I believe in my lifetime, I have witnessed the beginning, the struggle to make it somehow someway work, and in the end, it didn't. I watched a brave man with a dream bet everything, and I don't think it has turned out well. I admire those who have more guts than I've ever had to follow their dream. Google: Tribine Harvesters and there is tons of information on this subject.
Edited by DrAllis - 3 hours 31 minutes ago at 7:33pm |
AMB(wcIL)
Joined: 03 Oct 2009 Location: Chapin Il Points: 319 |
Posted: 3 hours 7 minutes ago at 7:57pm |
I remember seeing the Tri-bine at the Farm Progress Show a couple different times. I to was impressed that he chose the Gleaner platform for the base combine. Andy
Dennis J OPKs
Joined: 12 Sep 2009 Location: Overland Park, Points: 561 |
Posted: 2 hours 57 minutes ago at 8:07pm |
I had forgotten about this concept. I'm not clear if they're still building any. Saw this thing at a Farm Equip. Show in KC Mo. when it was being introduced. You can bet the Big Boys have not lended any support and probably done what they could to quash the idea. There is another monster machine from Europe out there making some test runs. Again, not sure what happened to it. From what I recall it was a transit nightmare. Probably another example of a good idea with not enough financing for the long-term battle. Dr., thanks for the reminder.
Posted: 2 hours 43 minutes ago at 8:21pm |
I just don't see where they are doing anything these days. The last public comments on anything from the owner was Oct, 2021.
AMB(wcIL)
Posted: 2 hours 13 minutes ago at 8:51pm |
Didn't someone in Indiana buy the Bi-rotor on tracks and was going to try and make it into a production machine? Andy
Joined: 11 Sep 2009 Location: illinois Points: 88838 |
Posted: 2 hours 3 minutes ago at 9:01pm |
Dennis J OPKs
Posted: 1 hour 58 minutes ago at 9:06pm |
That European machine/system was called Nexat out of Germany. It was undergoing testing here as late as 2024. Not sure if anything happened after that. Google has some information on it and there are videos. It's a beast.
Posted: 1 hour 48 minutes ago at 9:16pm |
I believe the Bi-rotor was purchased by John Deere and shelved. While it had some interesting features (like a rotating 360 degree cage/concave) it would have never matched the capacity of today's class 9-10 or 11 machines.
jvin248
Posted: 1 hour 32 minutes ago at 9:32pm |
Yes, both Tribine and Nexat were interesting machines and I followed them for quite a bit. Since then I saw the Brazil "agro never sleeps" guys and they think the whole US fascination with grain carts is absurd. I see their point. They buy a second combine instead of the cart+tractor. Same labor. They park the semi at the headland, combine down field until half full, turn and combine back next to the section they just combined so they know the yield/field is the same and get full just as they are at the semi and unload. Even though they are idle unloading, the second combine doing the same allows them to combine at 189% of a single combine and cart system. Plus they have a backup combine if either goes down. A recent set of videos on grain bag systems revealed a few operators avoiding the semi truck labor and excessive long weight traffic at the elevator. Specialized bag fill and empty machines. So I expect the next big idea in combines will be onboard large grain bags that get dropped like round bales or long beans, with two typical hoppers in them. Or round bale size to handle with skid steers. Almost like the old days of AC All-Crop combines with bagger chutes instead of a bin. . |
Posted: 20 minutes ago at 10:44pm |
When I run my brother's combine (6-30) in corn, depending on the field, I may take one round of 6 rows and a second round of 3 or 4 rows to end up with a full tank to dump. The field dictates what works, with waterways and row length. I have one long contour field where I take 4 rows down and back and have a full tank. The goal is to have as many bushels as possible before unloading. He plants 12-30's so I can do this. The negatives?? Over time and enough acres it will wear the center rows out faster on the corn head, but I'm not always the driver, so this isn't an issue (yet).
