Combine engine in a WD |
Cowman68
Joined: 04 Mar 2013 Location: Harris, n.c. Points: 33 |
Topic: Combine engine in a WDPosted: 29 Sep 2013 at 6:48am |
I bought a WD to make a pulling tractor for my dad , the man I got it from said it had the combine engine in it which should have plenty of power. We only pulled it 2 times it runs out of power. I'm not sure if it has the combine engine. How can I tell the difference between the standard WD engine and the combine engine ?
Posted: 29 Sep 2013 at 7:17am |
Pictures of both sides of the engine would be nice.
CTuckerNWIL
Posted: 29 Sep 2013 at 7:43am |
Look for numbers and letters stamped on the left rear ENGINE flange or on a pad on the side of the block below the air cleaner and report back.
Edited by CTuckerNWIL - 29 Sep 2013 at 7:44am |
Cowman68
Posted: 29 Sep 2013 at 7:51am |
I am not having any luck posting pictures and I have not found any numbers stamped on the block.
Cowman68
Posted: 29 Sep 2013 at 9:53am |
[Font]WD engine
cotncrzy
Joined: 07 Oct 2009 Location: TENNESSEE Points: 599 |
Posted: 30 Sep 2013 at 7:45am |
Thick head, External oil lines, oil filter. The actual front cover may have came off a WD, alot of the time the front cover is swapped. Again, the S/N should be between the carb and the rear of the engine.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Cowman68
Posted: 30 Sep 2013 at 9:20am |
It does have external oil lines and an oil filter. I will assume its a combine engine. It runs great and turns a lot of rpm's, and seems to have power. We pulled Saturday in 5000lb class and it ran out of power. I also pulled my d-17 In 5000lb and it had way more power. Just checking to see if anyone has any ideas for mor power .
cotncrzy
Posted: 01 Oct 2013 at 7:10am |
With stock tires, that engine should do well at 5000#. I ran one last year with 16.9x26 tires and could spin out hard in the 5000. Don't overlook the obvious, carb, ign. timing, valve clearance etc... When I say external oil lines I mean two running from spin on filter with female threads, (the WD and WD45 have male threads) horizontaly to around the dip stick, around 5/16 in size. I am not refering to the 1/8 line going to the head and governor box. I just bought another "combine" engine, I got to go pick it up this week. I will post some pics of the differences.
Cowman68
Posted: 01 Oct 2013 at 5:38pm |
Thanks for the help. I had high expectations from this tractor. I'll keep working on it .
cotncrzy
Posted: 02 Oct 2013 at 6:08am |
My first combine engine was a running engine when purchased. It was very dissapointing, we checked the compression on it after a couple of pulls, it was way down. Those engines were operated in the harshes conditions there could be, with all the dust and they wide open all the time. I have a pullin' buddy that took a fresh WD45 engine out to replace with a running combine engine with the "Z" code and it hurt his HP. Again, it needed rebuilding. I am not positive but I think it should be around 100 to 115 psi cranking compression.
Posted: 02 Oct 2013 at 6:26am |
Depending on which Gleaner "E" engine you have ( compression code Z or V or M) it will be 140 psi up to 180 psi. ...110 to 120 psi is WD45 compression.
Cowman68
Posted: 02 Oct 2013 at 6:34am |
Thanks for the info. I will check the compression on it this weekend and report back. I thought the engine was really good , because there was absolutely no smoke .
Posted: 02 Oct 2013 at 12:27pm |
All spark plugs removed.....throttle wide open.........battery charger on the battery to keep cranking speed consistent.
AC Billy
Joined: 27 Oct 2012 Location: Scottsburg,IN Points: 126 |
Posted: 03 Oct 2013 at 8:36pm |
Doesn't the combine engine have a
fuel pump boss? |
Glockhead SWMI
Joined: 12 Sep 2009 Location: South West Mich Points: 2657 |
Posted: 04 Oct 2013 at 8:25am |
Yes it does. You have to make a block off plate. I have a post in the farm section with pics of all the differences.
Cowman68
Posted: 06 Oct 2013 at 4:45pm |
Thanks for all the responses to my question. I have had a chance to check the compression on my tractor and it is about 65 lbs. my gage might not be up to par so I checked the compression on my d-17 and its about 125 lbs. Also the head thickness is the same as my d-17 . Is it a worn out combine engine ?
XT in pa
Joined: 21 Apr 2011 Location: hickory pa Points: 711 |
Posted: 06 Oct 2013 at 7:55pm |
It sounds like it. Was they all close to the same ?
190XT,D17and 7045
Cowman68
Posted: 06 Oct 2013 at 7:59pm |
The compression on al 4 cylinders were just about 65 lbs. but the engine runs with no smoke at all .
XT in pa
Posted: 06 Oct 2013 at 8:44pm |
I would think with it that low it should smoke. Did you ever try it at dark with a flash light aimed at exhaust ? I'd still say it needs a rebuild. If it's a puller maybe look into something a lil bigger. It don't cost a lot more than a stock build. Just a thought tho. Shawn.
190XT,D17and 7045
Posted: 07 Oct 2013 at 6:08am |
Sounds to me like someone ran a compression test with the throttle at an idle!!!!!!!! Throttle has to be wide open for a good compression test.
Cowman68
Posted: 07 Oct 2013 at 10:35am |
Yes, you are correct. I forgot to open up the throttle when I checked the compression. I'll check it again and report back. Thanks for the reminder.
Cowman68
Posted: 09 Oct 2013 at 5:44pm |
I have rechecked the compression on the WD with the throttle wide opened and it is still reading about 65 lbs on each cylinder.
